Key fob won't stay programmed.
Old Nov 28, 2003 | 11:52 PM
low98vette's Avatar
low98vette
Default Key fob won't stay programmed.
I have a98 vette and after you program the fob it works just one time then its out again. Any help would be greatly appreciated. I love this site. It rocks :party: Thanks Tate
Old Nov 29, 2003 | 03:30 PM
98silverC5's Avatar
98silverC5
Default Re: Key fob won't stay programmed. (low98vette)
Mine did the same thing, battery was going dead. Need to install a new battery then do a complete reprogram of all fobs (not just pressing lock & unlock). That cured my problem. :D
Old Nov 29, 2003 | 03:33 PM
Monster231's Avatar
Monster231
Default Re: Key fob won't stay programmed. (98silverC5)
replace abttery $1.29 at K-mart
Old Nov 29, 2003 | 08:52 PM
Colorado Chuck's Avatar
Colorado Chuck
Default Re: Key fob won't stay programmed. (Monster231)
For whatever reason, I had a somewhat similar problem even after changing the battery. Sometimes it worked, sometimes not. Knock on wood, but then it started working 100% of the time.
Old Nov 29, 2003 | 08:56 PM
NEPTUNEBILL's Avatar
NEPTUNEBILL
I've changed the battery and it helped, mine seems to get where I almost have to be on the hood of the car before it responds and lately it won't pop the hatch, it seems like the one I have for my tahoe has lasted for years with no probs, so to sum up mine is a pos as well---
Old Nov 30, 2003 | 12:24 AM
jimhild's Avatar
jimhild
Default Re: Key fob won't stay programmed. (NEPTUNEBILL)
In general the problem is the FOB and it needs to be replaced. Ebay typically has them for $35 - $40. The clasic FOB failure is to work one time after reprogramming then the security portion of the FOB doesn't work the next time.
:smash:
Old Nov 30, 2003 | 09:12 AM
low98vette's Avatar
low98vette
Thanks Guys :seeya I have replaced thebattery and it is still wrong :mad I guess I will have to buy a new fob. Thanks for all of the help.Tate :steering:
Old Nov 30, 2003 | 10:13 AM
bowtiebandit's Avatar
bowtiebandit
This may apply also..
RKE and/or Low Tire Pressure Monitoring System Inop (Replace RKE Module) #99-08-52-002 - (04/20/1999)
Remote Keyless Entry System (RKE) and/or Low Tire Pressure Monitoring System Inoperative (Replace RKE Module)
1997-98 Chevrolet Corvette
Condition
Some customers may comment on the following conditions:
The remote keyless entry system (RKE) is intermittently inoperative.
The Driver's Information Center is inoperative or it displays the following messages intermittently and usually at start-up of the vehicle:
Low tire pressure.
Tire pressure trouble codes may occur.
Cause
When the ambient temperature of the interior is less than 10° C (50° F), some oscillating transistors may stop working. However, when the interior warms, they begin to work with the next key cycle. The module in question is P/N 10401040.
Correction
Replace the RKE Module with P/N 10422621.
Parts Information
Part Number
Description
10422621
Module, Keyless Entry & Low Tire Pressure Module
To Key fob won't stay programmed.
