Keyless entry is no longer working
Old Nov 30, 2003 | 03:06 PM
juriah's Avatar
juriah
Default Keyless entry is no longer working
My Keyless entry has been a problem since I purchased my 1999 in 2001. I had to reprogram the handheld unit, if I did not open the doors or trunk within 2 days. Just recently it, was only working for hours and now minutes. Is it the tranmitter or the handheld remote? Any help you guys could offer would help.
:confused: :confused:
Old Nov 30, 2003 | 03:29 PM
JJ in FL's Avatar
JJ in FL
Default Re: Keyless entry is no longer working (juriah)
Could it be a weak battery?
Old Nov 30, 2003 | 03:46 PM
juriah's Avatar
juriah
Battery is a little over one year old. I had one of those great GM batteries, where the acid leaked out and eat a hole through my vacuum lines on A/C vent dampers. The DIC typically read about 14.1
Do you still think this may be the problem??
Old Nov 30, 2003 | 04:51 PM
JJ in FL's Avatar
JJ in FL
I would take the remote apart and clean the battery contacts.
Old Nov 30, 2003 | 04:58 PM
Monster231's Avatar
Monster231
Default Re: Keyless entry is no longer working (JJ in FL)
I think he is refering to the battery in the remote. a fresh battery works woneders, where as a weak one seems to last forever, but not performing well
Old Nov 30, 2003 | 08:32 PM
harleyvette's Avatar
harleyvette
This has happend to me also. I put in a new battery and reprogrammed but still it does not work properly. I think I will just buy new remote's.
Old Dec 1, 2003 | 02:40 PM
Got uid0's Avatar
Got uid0
St. Jude Donor '17
Default Re: Keyless entry is no longer working (harleyvette)
it is not the remotes, it is a problem with the transmiter on the car loosing sync with the remotes. You constantly have to reprogram them so they are on the same sync.
If it was weak battery it would not work at all or just sporadic and not simply magically work when you do a resync.
It is a problem GM is ignoring. IT is not the remotes
Old Dec 1, 2003 | 03:22 PM
5 Liter Eater's Avatar
5 Liter Eater
St. Jude Donor '11
Default Re: Keyless entry is no longer working (knowledgefreak)
I think it is the remotes. If I drop my remote I need to reprogram it and often I need to give it a few smacks to get it to work. The contacts in the remotes (at least the early remotes) are sketchy at best. They are flimsy and easily tweaked. Take it/them apart and see if you can see where the problem may lie. On mine, the positive and negative contacts were touching.
Old Dec 1, 2003 | 03:45 PM
cscollis's Avatar
cscollis
It is the reciever. I bet it was below 50 degrees when it stopped working. My froze up also and the tire pressure gages did not work. There is a service bullentine for this problem.
I replaced my reciever and all is fine now!
Old Dec 1, 2003 | 08:54 PM
harleyvette
Default Re: Keyless entry is no longer working (cscollis)
Where is this bulliten at? and was the new receiver covered under the warranty?
Old Dec 1, 2003 | 09:08 PM
huffyred00's Avatar
huffyred00
Cruise-In III Veteran
Covered under warrenty.. ordered one today from dealer.. I have two ,one has been used very little, the other I cary all the time.. The one I carry is the DEAD one .. new battery and still will only stay programed HOURS.. Check dealer....
Old Dec 1, 2003 | 11:32 PM
Could be a number of things - battery in the transmitter, the transmitter itself, the receiver in the car.
Old Dec 2, 2003 | 01:00 AM
HIGHRPM's Avatar
HIGHRPM
I scrapped the GM unit...never could keep it working properly...kept loosing sync with the reciever. I bought a Clifford system...does everything right...pops the rear hatch and the gas flap from the remote. Also pages me up the 1/4 mile if any forced entries are attempted.....the Clifford is what GM should have supplied instead of the junk remote system that in the C5...many, many Forum members have this problem and yet GM just keeps putting that crappy system in each new model. :U :U :U :U :U :U :U :U :U :U :U
Old Dec 2, 2003 | 01:38 AM
w8d4it's Avatar
w8d4it
St. Jude Donor '04-'05-'06-'07-'08-'09
How do you program the remote?
Old Dec 2, 2003 | 10:38 AM
9tee9c5's Avatar
9tee9c5
Default Re: Keyless entry is no longer working (HIGHRPM)
I have the same issue. The receiver should not be bad as I did two things to test. 1). The tire pressure sensors work;. 2). Went to GM and borrowed a new FOB and it programmed, then I was able to program my unit which gm tested as good. This was great until it lost sync AGAIN.
What is the Clifford System referred in the post? Any URL, etc.
Old Dec 2, 2003 | 09:00 PM
harleyvette
If this remote is a problem with so many owner's, why can't we get GM to replace these under warranty?
Old Dec 2, 2003 | 09:05 PM
harleyvette
Default Re: Keyless entry is no longer working (huffyred00)
Hi HuffyRed, You state that it is covered under warranty.
I went to my dealer and they said it was not covered!
Do you have any proof of this that I could show my dealer?
Old Dec 2, 2003 | 09:06 PM
bowtiebandit's Avatar
bowtiebandit
RKE and/or Low Tire Pressure Monitoring System Inop (Replace RKE Module) #99-08-52-002 - (04/20/1999)
Remote Keyless Entry System (RKE) and/or Low Tire Pressure Monitoring System Inoperative (Replace RKE Module)
1997-98 Chevrolet Corvette
Condition
Some customers may comment on the following conditions:
The remote keyless entry system (RKE) is intermittently inoperative.
The Driver's Information Center is inoperative or it displays the following messages intermittently and usually at start-up of the vehicle:
Low tire pressure.
Tire pressure trouble codes may occur.
Cause
When the ambient temperature of the interior is less than 10° C (50° F), some oscillating transistors may stop working. However, when the interior warms, they begin to work with the next key cycle. The module in question is P/N 10401040.
Correction
Replace the RKE Module with P/N 10422621.
Parts Information
Part Number
Description
10422621
Module, Keyless Entry & Low Tire Pressure Module
To Keyless entry is no longer working
