Head light grinds
Old Dec 1, 2003 | 05:41 PM
benelliwang's Avatar
benelliwang
Default Head light grinds
When I turn off my head lights, the driver side mechanism grinds for 6 to 10 seconds before it stops. It pops up ok and it only grinds in going back down. Any idea what the problem is?
thanks
Old Dec 1, 2003 | 10:45 PM
02blueelectron's Avatar
02blueelectron
Default Re: Head light grinds (benelliwang)
had the same problem. the dealer replaced the assembly on warranty for my 02 . seems that they have a problem of not retracting completely and takes a few seconds for the motor to grind them down and trip the off switch.
Old Dec 1, 2003 | 10:55 PM
Racer's Avatar
Cruise-In III Veteran
St. Jude Donor '11
Default Re: Head light grinds (02blueelectron)
:iagree: Warranty for me too.
Old Dec 2, 2003 | 12:05 AM
powderski13's Avatar
powderski13
Dealer replaced left side motor on mine for the same problem
Old Dec 2, 2003 | 02:34 AM
benelliwang
Default Re: Head light grinds (powderski13)
Bleh, I am out of warranty. What was replaced? :confused:
Old Dec 2, 2003 | 09:59 AM
sacsrpc's Avatar
sacsrpc
It is a stripped plastic gear inside the motor which causes this. You have two choices, replace the entire assembly, ($130+) or just buy a brass replacement gear from Rodney ($35)(can't remember his screen name).
I bought the replacement gear and had it done it about an hour.
Do a search on headlight and you should find the guy I'm talking about. :cheers:
To Head light grinds
