Why disconnect negative battery cable ?
Old Dec 6, 2003 | 09:42 AM
bowtiebubba's Avatar
bowtiebubba
Default Why disconnect negative battery cable ?
Hi, im going to install a new air bridge and a blackwing today and was wondering if it is necessary to disconnect the negative battery cable and if so why ? Thanks guys
Old Dec 6, 2003 | 10:04 AM
Y2Kvert4me's Avatar
Y2Kvert4me
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
Default Re: Why disconnect negative battery cable ? (bowtiebubba)
Most don't disconnect the battery, for the actual installation there isn't a need to.
Some say disconnecting it resets the computer, so it starts the relearn process faster. The computer will relearn and adjust for the additional airflow over time anyways. Don't expect a dramatic performance difference until you put 100 miles or so on it.
:cheers:
Old Dec 6, 2003 | 01:28 PM
carpe dm's Avatar
carpe dm
Default Re: Why disconnect negative battery cable ? (Y2Kvert4me)
:cheers:
It is also a CYA for the manufacturers because the C5 electrical/computor systems are sensitive and complicated. :yesnod:
Old Dec 6, 2003 | 01:56 PM
Red Rag Top's Avatar
Red Rag Top
If I remember correctly the Blackwing instructions call for disconnecting the MAF. If your going to do this I recommend you disconnect the bat.
Old Dec 6, 2003 | 10:40 PM
z-u-later's Avatar
z-u-later
Default Re: Why disconnect negative battery cable ? (Red Rag Top)
:iagree:
Old Dec 6, 2003 | 10:45 PM
Shortimer's Avatar
Shortimer
Default Re: Why disconnect negative battery cable ? (z-u-later)
I did an install of a twin-cone air intake and did not disconnect the battery. There was no need to do it. :chevy
Old Dec 7, 2003 | 01:43 PM
6 speed Sid's Avatar
6 speed Sid
I believe most call for the battery disconnect just a safety thing in case you hit something with 12 volts on it or cause the engine to turn over with your hand in something. Sid.
To Why disconnect negative battery cable ?
