gear change
Old Dec 6, 2003 | 03:37 PM
ydeer's Avatar
ydeer
Default gear change
i have ARE stage 2 heads,comp cam,flp exh,dbl roller chain, ls6 manifold, vararam b1,ported tb,etc,etc. my ?? is i'm installing LUK stage 2 clutch,alum flywheel. should i upgrade to 373 or 390 gears. i have 342 / mn6 now. i don't race or drag the car. its a 2000 vert with 5500 mi on it. all suggestions will be appreciated. thanks
Old Dec 7, 2003 | 12:33 AM
martin97c5's Avatar
martin97c5
Default Re: gear change (ydeer)
graham,
get the gear change it will be awesome. go 3.73 or 3.90
since we both need LS1 edit, lets drive to ECS in NJ and they will do the gear change and we can both get the ls1 edit
sound like a plan?
and if you dont wanna drive your car down there ill do it for you! :D
Martin :party:
Old Dec 7, 2003 | 12:52 AM
LittleBoyBlu99's Avatar
LittleBoyBlu99
3.90's all the way! :hurray: :hurray: :hurray:
Old Dec 7, 2003 | 11:43 PM
low flyier's Avatar
low flyier
Default Re: gear change (LittleBoyBlu99)
411's :D
To gear change
