I have a low coolant message that won't go away even on flat surface. I tried looking for the sensor but couldn't find it. Can anybody point me in the right direction? Thanks
The coolant sensor is mounted in the overflow jug. Make sure your coolant level is not low or it will trip the DIC warning. Some owners have reported a defective sensor - you may want to remove the jug and clean it out to dislodge any debris that may be clogging the sensor. Good luck.
