Hurst shifter owners, check in...........
Old Dec 11, 2003 | 06:01 PM
Buckmaster's Avatar
Buckmaster
Cruise-In III Veteran
Cruise-In V Veteran
St. Jude Donor '03-'04
Default Hurst shifter owners, check in...........
Did you remove the springs that Hurst puts in from the factory and use the two weakest springs (inner and outer spring?)? Did anyone use only one spring? Give me your thoughts on what everyone did.
Thanks. :)
Old Dec 11, 2003 | 06:03 PM
GaryZ06's Avatar
GaryZ06
Default Re: Hurst shifter owners, check in........... (Buckmaster)
Right now I have one light outer spring per side.....Perfect for me
Old Dec 11, 2003 | 06:10 PM
jmzvet's Avatar
jmzvet
Factory spring setup.
Old Dec 11, 2003 | 06:13 PM
99blackFRC's Avatar
99blackFRC
left mine as is..
Old Dec 11, 2003 | 06:23 PM
Cobra4B's Avatar
Cobra4B
CI 3-5-6-7-8 Veteran
Default Re: Hurst shifter owners, check in........... (99blackFRC)
Factory setup w/ the two allen screws loosened one full turn. You can loosed or tighten them one full turn. Tightening makes them stiffer and loosening makes thm softer.
Old Dec 11, 2003 | 06:35 PM
Buckmaster's Avatar
Buckmaster
Cruise-In V Veteran
Default Re: Hurst shifter owners, check in........... (Cobra4B)
Correct me if I'm wrong...the stock alignment pin is no longer used......right? Doesn't seem to be a place for it.
Old Dec 11, 2003 | 07:10 PM
Y2Kvert4me's Avatar
Y2Kvert4me
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
No, you don't need the alingment pin.
I used the lightest springs in mine.
:cheers:
Old Dec 11, 2003 | 07:29 PM
Buckmaster's Avatar
Buckmaster
Cruise-In V Veteran
Default Re: Hurst shifter owners, check in........... (Y2Kvert4me)
Did you use "Dual" lightest springs....or just the lightest "outer" spring (One per side)? Thanks :)
:cheers:
Old Dec 11, 2003 | 07:39 PM
Pumba's Avatar
Pumba
Buckmaster,
I removed the springs that came with my Hurst shifter and installed the lightest springs in the set. I found the lateral forces with the original springs to be unacceptably high.
Old Dec 11, 2003 | 07:44 PM
C5 StockSwap's Avatar
C5 StockSwap
Cruise-In V Veteran
St. Jude Contributor
Default Re: Hurst shifter owners, check in........... (Pumba)
I left mine in as they were delivered, but I may go to to the next lighter set on each side. Sound like I haven't run out of mods!
Old Dec 11, 2003 | 07:49 PM
LoneStarFRC's Avatar
LoneStarFRC
Default Re: Hurst shifter owners, check in........... (GaryZ06)
Same here, plus I backed off about one turn. Just be sure to use Loc-Tite on the threads.
Robert :D
Old Dec 11, 2003 | 07:55 PM
88sk's Avatar
88sk
Default Re: Hurst shifter owners, check in........... (LoneStarFRC)
stock for now,I read guys here mix springs on both sides, usually lighter on reverse side.
Old Dec 11, 2003 | 07:59 PM
Buckmaster's Avatar
Buckmaster
Cruise-In V Veteran
That's what I did for now. I used the lightest outer spring. I will see how that feels and adjust from there if needed. I put the retaining screws in 3 1/2 turns using Locktite.
Robert :D
Old Dec 11, 2003 | 08:04 PM
Maximillian2's Avatar
Maximillian2
Default Re: Hurst shifter owners, check in........... (88sk)
I used the heavy springs inside and outside. At first it
shifted a little hard. After you drive it for a week it feels
comfortable, at least it did for me. :party: :party:
Old Dec 11, 2003 | 08:38 PM
NVR BRNG's Avatar
NVR BRNG
Thus the conclusion from these posts is: with the Hurst you can "tune" it to feel just the way you want it to. Use the springs that feel best to you.
Old Dec 11, 2003 | 10:04 PM
CCrane65's Avatar
CCrane65
I tried the lightest springs on both sides at first but found that the shifter would rattle or vibrate a bit so I put the heavy spring back in on the passenger side so that it would be easy to shift into reverse.
It still seems a little wierd that you can lift the lever up but as long as it doesn't rattle I'm good.
BTW, be very very careful removing those screws so you don't drop them into the tunnel!
I lost one that way and had to buy a new one at the local Ace hardware.
cc
Old Dec 11, 2003 | 10:10 PM
Buckmaster's Avatar
Buckmaster
Cruise-In V Veteran
Default Re: Hurst shifter owners, check in........... (CCrane00)
Good advice. Thanks. I think I will try the lightest "outer" springs alone at first and see how it feels. If that doesn't feel good I will play around with the various springs.
Old Dec 11, 2003 | 10:37 PM
Admiral Fairway's Avatar
Admiral Fairway
Changed mine to the two lightest springs and backed off the set screw on turn.
Old Dec 12, 2003 | 09:08 AM
6Speeder's Avatar
6Speeder
Using it as it came from the factory. :steering:
To Hurst shifter owners, check in...........
