Harmonic balancer wobbling- is this normal?
Old Dec 14, 2003 | 02:24 PM
WildWolf's Avatar
WildWolf
Default Harmonic balancer wobbling- is this normal?
I took it to the dealer and they ordered the parts for me- will change it out next week as soon as the snow disappears. Did any of you guys have this problem? What causes it? I heard if I don't take care of it it could pretty much blow my motor.
Old Dec 14, 2003 | 02:39 PM
pdd000's Avatar
pdd000
Default Re: Harmonic balancer wobbling- is this normal? (WildWolf)
sounds like the pulley bolt came loose. definatly get it fixed asap
Old Dec 14, 2003 | 04:36 PM
RONS97C5's Avatar
RONS97C5
Most likely would do damage. I had the same problem 2 months ago, the rubber was coming out and the outer ring was cocked. Sounds like a perfect time for a under drive pulley :thumbs:
Old Dec 14, 2003 | 04:50 PM
Patches's Avatar
Patches
Default Re: Harmonic balancer wobbling- is this normal? (RONS97C5)
:iagree: Better yet, you're 9/10ths of the way to a funner cam. :D
Old Dec 15, 2003 | 05:07 PM
TeeJay's Avatar
TeeJay
As I recall there are 2 failure modes, internal and external - with internal being the far least destructive. Glad that you identified it early! Mine started to fail within a couple of blocks of the dealer so I was able to limp in without incident.
Old Dec 15, 2003 | 08:13 PM
Sack Rat TT's Avatar
Sack Rat TT
Glad you found your problem early. Imagine what could happen if your pulley/balancer came loose at high RPM in engine compartment? It would be a crap shoot regarding damage. Good Luck
:smash: :smash:
Old Dec 16, 2003 | 12:50 AM
rwj383's Avatar
rwj383
Default Re: Harmonic balancer wobbling- is this normal? (Sack Rat TT)
:smash: :smash:
I have had my pulley come off at high rpm's. Luckily on the C5 cars (unlike the f-body) the power steering rack is just in front of the pulley. So when mine came off it got trapped between the snout of the crank and the rack. Also, the snout is infinitely harder than the pulley hub material. The snout didnt get a scratch while the hub got wallared out big time. So, the worse that will happen is that you bounce the pulley around and ruin it, throw the accessory belt and start to overheat. Pull off the road and get a tow to the shop. Motor will only sustain damage if you let it overheat. I do recommend that the pulley is keyed the next time it is off, too. Extra insurance from this happening again.
Robert Judd
GenIII Motorsports, Portland, Or
[Modified by rwj383, 9:51 PM 12/15/2003]
Old Dec 16, 2003 | 01:04 AM
shaheen's Avatar
shaheen
Default Re: Harmonic balancer wobbling- is this normal? (rwj383)
I had a factory Harmonic balancer come off of my old 11.20 Mustang (yeah I know, I owned a Ford once in another life) at High RPMs. To add insult to injury, it hit the ground bounced back and put a hole in the oil pan.
That is why NHRA requires SFI approved Balancers.
Old Dec 16, 2003 | 08:35 AM
Jim 47's Avatar
Jim 47
Anyone:
If you have experienced a wobbling or loose harmonic balancer, what did the engine FEEL like when running?
Was there a VIBRATION when the engine was running?
Jim
Old Dec 16, 2003 | 10:16 AM
WildWolf's Avatar
WildWolf
Default Re: Harmonic balancer wobbling- is this normal? (Jim 47)
The engine feels ok- there is a slight vibration at around 1500 RPM. I originally thought I needed to change belts cause I heard the squeaking noise. Good luck! I would change cams but I have an extended warranty that I would like to keep intact. Also, I have read that underdrive pulleys can affect aftermarket stereo systems- i got 2 amps and an aftermarket headunit and changer.
Old Dec 16, 2003 | 12:10 PM
Jim 47's Avatar
Jim 47
Josh: Did you get the balancer replaced yet? An if so, did the sweeking and slight vibration at 1500 RPM go away?
Jim
Old Dec 16, 2003 | 12:32 PM
TeeJay's Avatar
TeeJay
In my case the engine felt fine and I can't recall detecting any vibration, I propably wasn't much outside the range of 1200 rpm but the noise was extreme - difficult to describe beyond metal-on-metal. By nature I expect that some failure modes and conditions of the balancer would yield various levels of vibration.
Old Dec 16, 2003 | 12:39 PM
Joe's Eray's Avatar
Joe's Eray
Mine fell off after having 52K miles on it. I was going to work one early morning and I heard this loud noise under my hood. At first I thought it was my radio but I turned the radio down and it was from underneath the hood. I limped back to my house and called a tow truck. Came to be the harmonic balancer went bad. I think it cost me 450 dollars to get it fixed with labor and a few new belts. I wish I would have known about putting a new aftermarket pulley in there or else I would have.
Old Dec 16, 2003 | 01:21 PM
C5stein's Avatar
0C5stein
Former Vendor
WildWolf,
MSI has seen alot of this problem on motors that are making over 460hp at the crank. Especially if you tend to rev it up. There are a few things going on; One is that the stock balancer is "Pressure/interference fit" to the snout of the crank. High revs combine with the added power tends to make the balancer "walk" on the crank, and makes the bolt stretch eliminating it's clamping force. The best fix, as the supercharged guys will tell you is to pin (key) the balancer to the crank. This keeps the balancer from turning on the crank. Use a 1/4" hardended round pin. A drilling fixture can be purchased from ATI, Vortech or Magnuson. We usually double pin them (with pins 180 degrees from each other).
Keep in mind that the Bolt that fastens the balancer to the crank is a "Torque to Yield" type bolt and only good for one use. DON'T USE IT TWICE!!!! (or it will fail again).
Good Luck and if you need anything else, just give us a call.
Mark
Old Dec 16, 2003 | 04:58 PM
WildWolf's Avatar
WildWolf
Default Re: Harmonic balancer wobbling- is this normal? (C5stein)
Thanks for the info!!!!! My car is at the dealer now- I don't think this car will ever have 460 at the crank. I will have a C6 before that happens. Good info none the less. :cheers:
Old Dec 16, 2003 | 05:23 PM
PewterVette's Avatar
PewterVette
I bet it's the crankshaft. I noticed that the crank pulley on my 2000 "wobbled" at 26k miles. Long story short, the crankshaft had a little warpage and the dealership replaced it under warranty. Problem solved. My Vette has 44k miles on it now and has never run better.
That noise was driving me crazy. It sounded like a bad belt, but worse. It was the most noticeable between 1500 and slightly over 2k rpm. Sometimes the noise went away after driving for a long period of time. The worst was when the engine was cold.
The good thing about my experience, although it was very time-consuming and a general pain in the butt, is that everything in the front of my motor was replaced with new GM parts, all belts, pullies, waterpump, you name it. GM didn't listen to me at first when I suspected it was the crankshaft and had the dealership replace everything else, only to find out they could have fixed the problem a whole lot sooner.
Hope this helps. Just thought I would share my experience since sometimes it is difficult to pin-point problems.
Adam
[Modified by PewterVette, 10:33 PM 12/16/2003]
Old Dec 19, 2003 | 10:24 AM
Jim 47's Avatar
Jim 47
Josh:
Just got back from a "second opinion" Chev Dealer. They said the vibration I feel and the screeching I hear is because the Harmonic Balancer is "coming apart". This confirms everything that this thread is saying. The first dealer that I took the car to couldn't find the source of the problem, but what burned me the most is, they said said they compared my car to other Vettes and there was NO difference. Don't you just hate it when people deliberately lie to you or are so incompetient that they can't properly diagnose a simple problem. I guess they just don't want my business, so I can accomodiate them and never go back there again. :D
Thanks to all you guys for the ideas and information posted here. It was very helpful to me. Have a Merry Christmas.
Jim Helm :thumbs:
To Harmonic balancer wobbling- is this normal?
