Oil Temperature
Old Dec 14, 2003 | 09:20 PM
bobby1999c5's Avatar
bobby1999c5
Default Normal Oil Temperature???
I just put a new cam in my car and I know that it is running a little lean because of the tuning from the old cam that I had in the car.
The coolant temperature seemed to run warmer after the change but when I gave it more gas, the temperature would decrease so I diagnosed it as a faulty thermostat. The temperature would go up to the higher 180's and lower 190's. After the thermostat change, it runs about 4-6 degrees(178) more than normal.
My question is what is the normal operating temperature for the oil because it probably is a better indicator of engine operating temperature. Mine is 198 right now and I never paid attention to it before so I'm wondering if this is normal after about twenty minutes of driving. I use Mobil 1 oil if that makes a difference.
[Modified by bobby1999c5, 2:22 AM 12/15/2003]
[Modified by bobby1999c5, 2:24 AM 12/15/2003]
[Modified by bobby1999c5, 2:27 AM 12/15/2003]
Old Dec 14, 2003 | 09:26 PM
Y2Kvert4me's Avatar
Y2Kvert4me
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
Default Re: Normal Oil Temperature??? (bobby1999c5)
198 seems a little low for oil temp actually.
Mine normally runs in the 210 ballpark. The highest I've seen was 245 this past summer.
:cheers:
Old Dec 15, 2003 | 11:20 AM
Mitch Alsup's Avatar
Mitch Alsup
Default Re: Normal Oil Temperature??? (Y2Kvert4me)
You actually WANT the oil to reach 212 degrees in normal running, just to make sure that all the water vapor is driven off the oil and this prevents corrosiion in those sections of the engine serviced by oil. On the other end, you need the oil to remain below 300 degrees to avoid loosing viscocity and allowing metal to metal contact. Some might say 285 instead of 300, but remember, we are talking Mobil 1. In any event, few will see these temperatures unless they visit road racing tracks and drive for extended periods of time.
Old Dec 15, 2003 | 12:21 PM
Mr. Jones's Avatar
Mr. Jones
Default Re: Normal Oil Temperature??? (Mitch Alsup)
197 to 227 are typical oil temps for me
thats withstock fan/thermo setup
Old Dec 15, 2003 | 12:43 PM
carpe dm's Avatar
carpe dm
If you are running lean, you are running hotter too. Get this checked out and have you fuel delivery programmed to correct the situation. Comments on oil temps above, are right on. :thumbs:
Old Dec 15, 2003 | 01:10 PM
jschindler's Avatar
jschindler
Default Re: Normal Oil Temperature??? (carpe dm)
During our hot summers mine runs 210 - 215 during "normal" driving. I noticed yesterday with the temps in the 50's that cruising at about 65 mph it was at 198, so I think you are right about normal.
Old Dec 15, 2003 | 02:04 PM
Zen06's Avatar
Zen06
:iagree: Mobil1 is good to 400 degrees, but I wouldn't want to try it in an aluminum block and heads. :mad
Old Dec 15, 2003 | 06:44 PM
bobby1999c5
Default Re: Normal Oil Temperature??? (Zen06)
Thanks for all of the responses. I'm getting the car tuned tomorrow, so I guess we'll see if it will run any cooler or if it is lean at cruising speeds.
Thanks,
Bobby
To Oil Temperature
