Fuel Filter
Old Dec 15, 2003 | 09:32 PM
cortex's Avatar
cortex
Default Fuel Filter
Crap! I can't get this stupid tool inside the filter to get the line out. :cuss Does a '99 have a 3/8ths or 5/16th's fuel line?
Wrong tool perhaps? I am using one that looks like this....
[Modified by cortex, 8:32 PM 12/15/2003]
Old Dec 15, 2003 | 10:36 PM
luvinc5's Avatar
luvinc5
Default Re: Fuel Filter (cortex)
It's a bit of patience to get it in inside the fitting to slide it off. However, the tool does work as intended.
Remember to relieve the fuel pressure in the line before removing the filter.
Old Dec 15, 2003 | 10:41 PM
vetterdstr's Avatar
vetterdstr
CA Events Coordinator
That tool will work... just insert it into the tapered area firmly, then pull the line out.
VR :cheers:
Old Dec 15, 2003 | 10:57 PM
cortex's Avatar
cortex
Default Re: Fuel Filter (vetterdstr)
:banghead: :banghead:
4 hrs of trying so far.
Old Dec 15, 2003 | 11:00 PM
vetterdstr's Avatar
vetterdstr
Something is wrong... if you cant get it. Take it to the dealership and they will replace it for you... You really dont want to screw up that line... I did and it was a $600 repair.
VR :cheers:
Old Dec 16, 2003 | 12:12 AM
cortex's Avatar
cortex
Woohoo, got it, although I scuffed up the line pretty bad. I think it was that piece of poopie tool I posted up top. I would not recommend that thing to anyone. I also tried the cheap plastic rings - that didn't work either.
I got one of these, hit it with a hammer a few times and it worked. The others don't have a surface you can get a hammer onto...
:cheers:
p.s. The tech tip says use a 5/16ths tool. On my '99, it required a 3/8ths. :steering:
[Modified by cortex, 11:13 PM 12/15/2003]
Old Dec 16, 2003 | 12:39 AM
vetterdstr's Avatar
vetterdstr
:cool:
Old Dec 16, 2003 | 09:17 AM
6SPD98's Avatar
6SPD98
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18- '19
________________________________________ ________________________
Nice fuel line disengagement tools........where did you purchase them? How much. I see you work at Vanderlay Industries, do you know George Castanza?
Old Dec 16, 2003 | 10:42 AM
bowtiebandit's Avatar
bowtiebandit
Cortex..I had the same crappy tool you first got and since switched to the same set you had success with, amazing the difference it made. :cheers:
Old Dec 16, 2003 | 11:24 AM
cortex's Avatar
cortex
Default Re: Fuel Filter (vette#one)
That set can be purchased from http://www.arizonatools.com/
I just bought a 3/8" tool that looks like that seperately from O'Reilly Auto Parts. It is the Performace Tool brand. Part # W83131.
Oh, yeah, George and I go way back :lol:
Old Dec 16, 2003 | 12:24 PM
Fast one's Avatar
Fast one
I used a small screw driver.
Old Dec 16, 2003 | 02:38 PM
myblackC5's Avatar
myblackC5
are the fuel filters different from 98 to 99? mine came right off
Old Dec 17, 2003 | 09:56 AM
EWill3rd's Avatar
EWill3rd
Some of the newer ones are different, they have plastic squeeze clips instead of the internal spring lock.
Like bowtie, I use the goldish colored one displayed in the later photo.
Sometimes on automatics I remove the left muffler for some more access.
The key in removal is to insert the tool, push the line and the filter TOGETHER then release the tabs by sliding the tool in and then the line comes out easy, fuel pressure should be relived using an approved method beforehand.
If you pull them apart while you push the tool in you will never get it to release, you have to push them together. (the line and the filter)
EWill
Old Dec 20, 2003 | 04:02 AM
pltmgr's Avatar
pltmgr
I used the cheap plastic set on my 99 6spd with no problem. Also used them on my olds van and mother-in-law's saturn.
Old Jan 5, 2005 | 08:52 AM
Bling Bling's Avatar
Bling Bling
What is a good mileage to replace the fuel filter?
Old Jan 5, 2005 | 09:26 AM
USA-VET's Avatar
USA-VET
VR
Old Jan 5, 2005 | 09:27 AM
USA-VET's Avatar
USA-VET
It only cost me $75 to have it done, not bad Filter $50 labor $25
To Fuel Filter
