Brake stuff
Old Dec 16, 2003 | 03:10 AM
yeagerda's Avatar
yeagerda
Default Brake stuff
A couple of questions...
- 2003 coupe with 10k miles (5 months new) starting to show signs of rotor warp. Is this to be expected? Should these be turned, or replaced/upgraded?
- Z06 claims shorter 60-0 stopping distance. Is any of this attributable to brakes, or merely due to larger footprint tires?
Old Dec 16, 2003 | 10:58 AM
carpe dm's Avatar
carpe dm
Default Re: Brake stuff (yeagerda)
Your Z MAY have rotor warping, but it might also be build-up of pad material on the rotor. I would first be sure the rotor faces and the inner sides of the wheels are clean, and the wheels are torqued correctly. (BTW, if you have not removed the wheels yet and retorqued them, this might be the problem.) Use some emery cloth or sand paper to clean and cross-hatch the rotor faces (you can do the pads too), and then drive the car to check for improvement. :yesnod: :)
Old Dec 16, 2003 | 03:31 PM
Fast one's Avatar
Fast one
Default Re: Brake stuff (carpe dm)
Also check the hub to rotor area for rust build up which can be cleaned up with a wire brush.
Old Dec 16, 2003 | 03:42 PM
Mel 2001's Avatar
Mel 2001
My rotors were turned at dealership just before my 3yr warranty was up. 25k miles. No charge. :D
Old Dec 16, 2003 | 10:42 PM
VetteDrmr's Avatar
VetteDrmr
The improved Z06 stopping distances are due primarily to the tires, the brakes are the same between C5s and Z06s.
Here's another thing you can do to try to smooth out your rotors: Check out the Tech Tips on http://www.baer.com and "re-season" your rotors. Many times this will burn off the deposits that are on your rotors. May not fix it but won't hurt anything either, if you follow the directions.
HTH, and have a good one,
Mike
To Brake stuff
