Engine Bottom End
Old Dec 17, 2003 | 09:06 AM
100Bucks's Avatar
100Bucks
Default Engine Bottom End
The connecting rods in our engines are powdered metal. Does anyone know whether the crankshaft is cast or forged?
Old Dec 17, 2003 | 09:25 AM
GmPartsDirect.com's Avatar
0GmPartsDirect.com
Former Vendor
Default Re: Engine Bottom End (100Bucks)
100Bucks,
The Crankshaft Assembly is a nodular iron cast with undercut and rolled fillets. Casting P/N 12552216.
Marc
TECH 1794 http://WWW.GMPartsDirect.com http://www.gmpartsdirect.com/results.cfm?specials=1
:flag :flag :flag
Old Dec 17, 2003 | 09:29 AM
100Bucks's Avatar
100Bucks
Default Re: Engine Bottom End (GmPartsDirect.com)
Thanks for the info!
Old Dec 17, 2003 | 04:57 PM
dads01dream's Avatar
dads01dream
Sooo, does that make the crank a good one? If somebody was looking into doing a "forged bottom end" would it require a new crank too? How much HP can the stock crank support? :seeya
Old Dec 17, 2003 | 05:27 PM
kumar75150's Avatar
kumar75150
Default Re: Engine Bottom End (dads01dream)
I think you can live with a stock crank unless you are going pretty extreme. I havent really heard of any cranks failing. I would say 600rwhy easy.
Old Dec 17, 2003 | 07:43 PM
Bink's Avatar
Bink
Cruise-In V Veteran
St. Jude Donor '09
Default Re: Engine Bottom End (kumar75150)
:iagree:
Old Dec 17, 2003 | 07:46 PM
100Bucks's Avatar
100Bucks
I'm an old drag racer but a new C5 owner. I'm probably old fashioned or out of step with the modern technology in these fine cars, but I personally would be skeptical about twisting one of these stock bottom ends too tight.
I really don't know too much about powdered metal connecting rods and how they stack-up against forged or billet rods but I would think that if you were wanting to spend a lot of time at 6000 rpm and up, you'd be really rolling the dice doing it with a cast crank.
Maybe I'm out of touch with this because I've seen lots of threads on this site with folks installing all kinds of bolt-on stuff and putting out pretty big numbers and apparently having the engines live.
But then again maybe they just don't post when they scatter it. :jester
So, I take it that these stock bottom ends are pretty rugged?
Old Dec 18, 2003 | 09:04 AM
CanoeU's Avatar
CanoeU
i've seen a few posts about broken connecting rods....now if search would just work for me this once!! :nonod:
Old Dec 18, 2003 | 10:51 AM
100Bucks's Avatar
100Bucks
Default Re: Engine Bottom End (CANOE U)
I have a little trouble with the search feature as well.
Sometimes I have typed-in the exact title of a thread that I know exists and the search says it can find no such animal.
This is an important skill to master because if you start a thread that has been discussed before you sometimes incur the wrath of the veterans here.
Old Dec 18, 2003 | 11:00 AM
Daryl's Avatar
Daryl
The search option can sometimes be frustrating, but it works.
Old Dec 18, 2003 | 11:03 AM
Heretic's Avatar
Heretic
The crank is fine, if you are going to twist it 7000+ alot, then you might need new rods.
I think the stock rods with ARP bolts, stock crank and forged pistons ought to be plenty for 99.9% of the street-strip cars.
For my car, I will probably even stay with hypereutectic pistons.
To Engine Bottom End
