Torque Specs for frt/rear shocks
Old Dec 17, 2003 | 12:04 PM
kraff's Avatar
kraff
Default Torque Specs for frt/rear shocks
I'm putting the '04 Z shocks in and can't seem to find torque specs for the bolts. I don't do that much wrenching on the car, so I don't want to buy a manual. I'd appreciate it if someone could help :cheers:
Old Dec 17, 2003 | 12:52 PM
Cruises's Avatar
Cruises
Default Re: Torque Specs for frt/rear shocks (kraff)
you might try http://www.ls1howto.com I found a list of torque specs for engine, trans, and clutch but I don't have anything for shocks. :cheers:
Old Dec 17, 2003 | 12:57 PM
Patches's Avatar
Patches
Installation Procedure - Front Shocks
Install the retainer and insulator to the shock absorber.
Install the shock absorber to the upper shock tower.
Notice:
Use the correct fastener in the correct location. Replacement fasteners must be the correct part number for that application. Fasteners requiring replacement or fasteners requiring the use of thread locking compound or sealant are identified in the service procedure. Do not use paints, lubricants, or corrosion inhibitors on fasteners or fastener joint surfaces unless specified. These coatings affect fastener torque and joint clamping force and may damage the fastener. Use the correct tightening sequence and specifications when installing fasteners in order to avoid damage to parts and systems.
Install the upper insulator, retainer, and nut. Tighten
Tighten the shock absorber upper mounting nut to 26 N·m (19 lb ft).
Install the shock absorber lower mounting bolts and nuts. Tighten
Tighten the shock absorber lower mounting nuts to 28 N·m (21 lb ft).
Connect the real time damping electrical connector to the shock, if equipped.
Remove J 33432-A from the spring.
Install the tire and wheel assembly. Refer to Tire and Wheel Removal and Installation in Tires and Wheels.
Lower the vehicle.
For vehicles equipped with heavy duty shocks (FE3) perform the following steps.
Install the J 43822 to the shock absorber.
Install the shock absorber into the vehicle.
Remove J 43822 from the shock absorber.
Install J 33432-A to the spring and compress.
Raise the lower control arm and install the shock absorber lower mounting bolts and nuts. Tighten
Lower the vehicle.
Installation Procedure - Rear Shocks
Install the upper insulator and insulator retainer to the shock absorber.
Install the shock absorber to the shock tower and to the lower control arm.
Install the tie rod from the control arm. Refer to Tie Rod End Replacement - Outer .
Install the upper shock absorber mounting bolts.
Notice:
Install the lower shock absorber mounting bolt. Tighten
Tighten the upper mounting bolts to N·m (22 lb ft).
Tighten the shock absorber lower mounting bolt to 220 N·m (162 lb ft).
Connect the shock absorber solenoid electrical connector, if equipped.
Lower the vehicle.
Old Dec 17, 2003 | 01:19 PM
kraff's Avatar
kraff
Default Re: Torque Specs for frt/rear shocks (Patches)
Thanks mucho Patches! I think this is at least the second or third time you've helped me out. 162lb wow. I need a new torque wrench :yesnod:
:cheers:
To Torque Specs for frt/rear shocks
