How to prevent burnt plug wires
Old Dec 17, 2003 | 05:51 PM
Z06ufgrad2002's Avatar
Z06ufgrad2002
Default How to prevent burnt plug wires
Ok everyone, I am looking for some real world experience info on the best product/technique to prevent burnt plug wires after a header install.
I spoke to the Taylor rep today and he said that even the Cool Socks product will not prevent the wires from getting burnt. He said the heat will go right through the product. He suggested header wrap (the stuff that looks like an ace bandage), which is not something I care to do.
Any other suggestions????
TIA :confused: :confused:
Old Dec 17, 2003 | 06:10 PM
FRISKY's Avatar
FRISKY
Cruise-In III Veteran
Default Re: How to prevent burnt plug wires (Z06ufgrad2002)
He suggested the two best ways to keep the wires from being torched. Do both! You don't need to wrap the whole header, just the spot where the wires are close to the tubes.
Old Dec 17, 2003 | 06:17 PM
Buckmaster's Avatar
Buckmaster
Cruise-In V Veteran
St. Jude Donor '03-'04
I have headers and have the "Firesleeves" from Thunderracing.com...and have never had an issue. I am using the 10.4 mm Taylor wires too :)
Old Dec 17, 2003 | 06:27 PM
XTrooper's Avatar
XTrooper
Check out these spark plug wires. These are what I've been using with great success. :yesnod:
http://www.jegs.com/cgi-bin/ncommerc...47&prmenbr=361
Old Dec 17, 2003 | 11:58 PM
molon labe's Avatar
molon labe
you can also use plug wire boot shields. helps alot. and then check out header wrap and socks. you'll be fine. :)
Old Dec 18, 2003 | 04:27 PM
FKING1's Avatar
FKING1
Default Re: How to prevent burnt plug wires (tattooed)
With my B&B headers and socks one wire burned. Got MSD wires that are perfect length to clear the headers and have not burned any, no socks.
Fred K.
To How to prevent burnt plug wires
