Need help on re-program the remote
Old Dec 18, 2003 | 11:28 PM
NXVette's Avatar
NXVette
Default Need help on re-program the remote
Please show me how to program my remote :confused: Thank you :cheers:
Old Dec 18, 2003 | 11:37 PM
Sack Rat TT's Avatar
Sack Rat TT
Default Re: Need help on re-program the remote (NXVette)
Owners Man has procedure. Be close to your car and press and hold both the lock and unlock buttons together at the same time on the remote and hold for up to 15-20 seconds. Horn should beep alerting you to the now syncronized remote. Hope this is what you were asking for. Good Luck and let us know if this helps.
Old Dec 18, 2003 | 11:43 PM
bowtiebandit's Avatar
bowtiebandit
Turn the ignition to ON.
Turn the radio to OFF.
Press the RESET button in order to clear any IPC warning messages.
Press and release the OPTIONS button on the DIC to scroll through the display options until the IPC display is blank.
Press and hold the RESET button for 3 seconds.
Press the OPTIONS button until FOB TRAINING message is displayed.
Press the RESET button in order to begin the programming sequence. The message HOLD LK + UNLK 1ST FOB will be displayed.
Simultaneously press and hold the LOCK and UNLOCK buttons on the first transmitter for 15 seconds. The IPC will indicate when that transmitter is programmed and when to proceed to the next. Repeat this procedure for each additional transmitter or press the OPTIONS button to exit.
Old Dec 19, 2003 | 12:23 AM
ROCKnROLL's Avatar
ROCKnROLL
Veteran
follow the replies from the two members above me.
try the procedure sack rat tt told you, if that doesn't work then do the procedure bowtiebandit gave you.
hopefully that should take care of you.
Old Dec 19, 2003 | 08:11 AM
NXVette's Avatar
NXVette
Default Re: Need help on re-program the remote (ROCKnROLL)
Thank you everybody :cheers:
Have a nice weekend.
To Need help on re-program the remote
