Please help!!! I have a question about a wire we cant identify
Old Dec 19, 2003 | 12:50 AM
EricG33's Avatar
EricG33
Default Please help!!! I have a question about a wire we cant identify
Ok, I'm reassembling the front end of the car by putting in the radiator, electric fans, radiator support etc....I noticed a wire coming off a main wiring loom...its actually two wires an orange wire and a black wire wrapped together with what seems to be a severed end since i see copper wiring coming out of the ends of them. This wiring loom and wires in question are located by the passenger side fog light/horns. The wires are about 8 inches in length and wrapped together with black tape. With the radiator support in place you wouldnt be able to see this area unfortunately for me. Does anyone have a clue where this wire(s) got to?? Could they possibly just be accessory type wires which arent used??? Please help.....I"m losing sleep frettin' about this deal. Thanks in advance, Eric :confused:
Old Dec 19, 2003 | 01:14 AM
IrishMac's Avatar
IrishMac
Moderator Emeritus
Gone, but not Forgotten
Cruise-In 5, 6, 8 & 10 Veteran
St. Jude '03-'04-'05-'06-'07-'08-'09
Default Re: Please help!!! I have a question about a wire we cant identify (EricG33)
I have no idea, but "wrapped together with black tape" sounds like maybe an aftermarket job?
Good luck on this one. :thumbs:
[Modified by 98BlackMagic, 12:21 AM 12/19/2003]
Old Dec 19, 2003 | 01:38 AM
EricG33's Avatar
EricG33
Default Re: Please help!!! I have a question about a wire we cant identify (98BlackMagic)
I should have been more specific. The "black tape" is the factory type black tape that comes off some factory wire looms. Thanks,Eric
Old Dec 19, 2003 | 04:58 AM
markcz's Avatar
markcz
I was planning on putting my '01 Coupe on the ramps later today, I'll take a peek and see if I can find them.
:cheers: :lurk:
Old Dec 19, 2003 | 08:19 AM
markcz's Avatar
markcz
Those are the wires that supply your underhood light. They are supposed to go to a connector that is mounted next to the air box, about half way up on the passenger side. I would guess that the bare wires you see were pulled straight out of the connector. If you just find the wires coming out of the hood light and butt-splice them together you should be fine. FYI, the wires that come out the other end of the connector and go to the light are both black.
:cheers:
Old Dec 19, 2003 | 09:34 AM
vettemaster1's Avatar
vettemaster1
i have the same wire loom on my car. i noticed them when i installed a vararam. i have owned my car since new. this wire loom is by the horns . i could not find where it went either. everything else was in order so i just left it. :rolleyes:
Old Dec 19, 2003 | 10:06 AM
BlueDragon's Avatar
BlueDragon
Just a note of caution, your Air Bag wires run through that same area as well. I had mine apart to replace the skid bar assembly. Can't remember the wire colors, but they all run in that same main loom on the passangers side. Be very careful around that air bag trigger sensor, or you will be doing a very expensive interior clean up! I may bell be the underhood light or horns.
Jer
Old Dec 19, 2003 | 10:32 AM
corvette184's Avatar
corvette184
Default Re: Please help!!! I have a question about a wire we cant identify (BlueDragon)
i think that may be your exterior temp sensor.....there is a small black plastic probe in that area....my car is up in the air right now....i can snap a pic if you like :thumbs:
Old Dec 19, 2003 | 10:37 AM
BlueDragon's Avatar
BlueDragon
Default Re: Please help!!! I have a question about a wire we cant identify (corvette184)
Good catch I forgot all about that one! And that one has given me trouble, I had to change the sensor. Is that a orange wire?
Jer
Old Dec 19, 2003 | 10:41 AM
vettemaster1
good catch, i dont have dual zone a/c and that is probally why the wire is just hanging. :seeya
Old Dec 19, 2003 | 11:36 AM
EricG33's Avatar
EricG33
Default Re: Please help!!! I have a question about a wire we cant identify (vettemaster1)
Thanks so much for all of the responses!!! I can sleep again :D . Corvette 184 if you could send me that pic I would greatly appreciate it!!! Thanks again all, Regards, Eric
Old Dec 19, 2003 | 11:49 AM
runamuk's Avatar
runamuk
Cruise-In V Veteran
St. Jude Donor '04
:iagree:
Thats exactly what I was thinking.
Old Dec 19, 2003 | 01:25 PM
markcz's Avatar
markcz
OK, anyone who doesn't have the automatic HVAC controls won't have the outside ambient air temperature sensor, so they might have a loose connector in the area that Eric found the loose wires. However, those wires are supposed to be Light Green w/Black stripe and Gray w/Black stripe. ;)
About 6" from the where the air temp sensor wires sit, there is another pair of wires, one Black and one Orange, that supply power to the underhood light. :D
I don't think C5's have air bag sensors in the bumpers, but if they did the wires would most likely be Yellow. I'm pretty sure that C5's use an accelerometer/computer combination under the radio to deploy the air bags. :smash:
Since Eric described the mystery wires as Black and Orange, my $ is on the underhood light. :hurray:
And the winner is..............
Old Dec 19, 2003 | 01:51 PM
corvette184
Default Re: Please help!!! I have a question about a wire we cant identify (markcz)
i just double checked the spare temp sensor i have on the shelf......you are correct on the color coding...i have a maunual in frt of me ..but i get a headache :crazy: looking at wiring schematics :crazy: :crazy: here is a pic of the sensor wiring
[Modified by corvette184, 6:52 PM 12/19/2003]
Old Dec 19, 2003 | 08:07 PM
BlueDragon's Avatar
BlueDragon
Nope, the airbag sensor is on the bottom of the front cross member right under the center of the hood. Just don't bang it by accident, as it is a one time deal. If you hit it hard enough?? I have had mine out, as I had to remove the harness to get the front Skid Bar assey. out and replaced. On the driver side you have the AIR mount and harness and on the passanger side the loom holds the temp probe, horns, airbag sensor, and hood light. And they all twist around that bar so that you have to disonnect them to replace the dam thing!
It is not under the radio!
I do my own work, even some of the heavier lifting stuff.
Jer
Old Dec 20, 2003 | 12:12 AM
EricG33's Avatar
EricG33
Thanks so much to you all for your research and comments. Mark was correct in his diagnosis of the under hood light wiring assembly. The temperature probe sensor had different colored wires but was at least another good idea of something to check. I fixed everything and all is good again. Thanks again, Eric :cheers:
Old Dec 20, 2003 | 05:54 AM
markcz's Avatar
markcz
:party: Glad I could help Eric!
BlueDragon.....It appears we were BOTH right about the airbag sensor. My '01 Service Manual doesn't ever mention a front mounted trigger, but my '97-'01 parts CD shows a sensor mounted right where you said it would be on pre-'99 C5's. It looks like the rest of the system stayed pretty much the same, only no sensor on the front bumper after '98. :confused: I guess they determined that the accelerometer was good enough.
:cheers:
Old Dec 20, 2003 | 05:52 PM
BlueDragon's Avatar
BlueDragon
Well, I'll be! :jester They changed them :lolg: :lolg: :lolg:
To Please help!!! I have a question about a wire we cant identify
