LineLock & your 6 speed
Old Dec 23, 2003 | 10:46 PM
z-u-later's Avatar
z-u-later
Default LineLock & your 6 speed
Do you use a line lock w/ your 6 spd gearbox
or)
Do you just heat up the tires in the waterbox w/ 2nd gear burn out
or)
1st gear burn out in the waterbox.
[Modified by z-u-later, 9:46 PM 12/23/2003]
Old Dec 23, 2003 | 11:13 PM
BADBLACK99's Avatar
BADBLACK99
Default Re: LineLock & your 6 speed (z-u-later)
I don't have one yet although I'll get it as soon as Cartek has one available for active handling cars. Others seem like a nigtmare to install. As for burnouts I do 2nd gear for a few seconds at 4000-5000 and then roll out of it up to about 6000. I would love to hear any input about an easier to install linelock. :lurk: :thumbs:
Old Dec 23, 2003 | 11:46 PM
z-u-later's Avatar
z-u-later
Default Re: LineLock & your 6 speed (BADBLACK99)
I think Cartek has one available KH24 has it.
Old Dec 24, 2003 | 12:38 AM
66ImpalaLT1's Avatar
66ImpalaLT1
I use a hurst line lock.
Old Dec 24, 2003 | 09:04 AM
Paul_Z06's Avatar
Paul_Z06
Default Re: LineLock & your 6 speed (66ImpalaLT1)
I had Cartek install one for me afer I cracked both rear rotors from all the powerbreak burnouts.
Old Dec 24, 2003 | 09:05 AM
BadBeagle's Avatar
BadBeagle
Cartek put line lock on my 6 spd and I have active handeling. Line lock works fine at the track and I haven't notice anything unusal with the active handeling.
Old Dec 24, 2003 | 10:26 AM
z-u-later's Avatar
z-u-later
Default Re: LineLock & your 6 speed (99BlueCoupe)
Where was the button located to activate the system?
Old Dec 24, 2003 | 12:23 PM
BadBeagle's Avatar
BadBeagle
Dave put it right next to the cigarette lighter. I didn't want the wife to see it because I didn't want to have to explain what it was. She just wouldn't understand.
Old Dec 24, 2003 | 12:53 PM
kh24's Avatar
kh24
Mine is rigged the hand held switch that comes with the hurst roll control. It is tucked away in the ashtray when not in use so its out of site.
Old Dec 24, 2003 | 02:18 PM
z-u-later's Avatar
z-u-later
Yes this is the reason why I ask of the location :lol:
Old Dec 24, 2003 | 04:37 PM
Buckmaster's Avatar
Buckmaster
Cruise-In III Veteran
Cruise-In V Veteran
St. Jude Donor '03-'04
Is the line-Lock different for the 6 speed than an A4? Sorry for the elmentary question. :)
Old Dec 24, 2003 | 09:45 PM
WALLstAL's Avatar
WALLstAL
St. Jude Donor '05
Default Re: LineLock & your 6 speed (Buckmaster)
The line lock is the same (different brands), however some like a different activation method. This is the best for me with the A4 that come with the TCI Roll Stop kit.
[Modified by wallstAL, 6:48 PM 12/24/2003]
Old Dec 24, 2003 | 10:33 PM
Terry Burger's Avatar
Terry Burger
If you can't do a water box burnout without a line lock, I have to ask if your reflexes are quick enough to properly control the car should something come up?
Old Dec 25, 2003 | 01:37 PM
Paul_Z06's Avatar
Paul_Z06
Default Re: LineLock & your 6 speed (Terry Burger)
It isn't difficult to do a burnout without line lock but not having one beats the crap out of your rear brake pads and rotors. You just have to rev up to 4500 rpm or so, dump the clutch, and move your left foot quickly from the clutch to the brake pedal. Once you're done, let up on the brake so you roll out but then get get back on the clutch with your left foot and on the brake with your right foot while easing up on the throttle. Just make sure you don't take out the track officials in front of you. :eek:
To LineLock & your 6 speed
