Racing Tips for Beginners - Long
Old Dec 25, 2003 | 02:23 AM
AZCARGASM's Avatar
AZCARGASM
Default Racing Tips for Beginners - Long
These tips are for one of the local tracks, so ignore references to specific names and areas, but I thought most of the info for new racers is good, and more important, concise and complete.
Happy and Healthy Holidays to Everyone.
Drag Racing Tips for Beginners
by Michael D. Metzler, adapted from an article by Jeff Tyler
1. Speedworld Motorplex has a "Friday Night Challenge", or "Test and Tune" most every Friday night except for certain events (Winter Schedule is Saturday Mornings). There is also a "Street Racer" Wednesday night race, at different times through the year. Check the racer hotline and/or website schedule each week before going to the track for up to date information. On Wednesday and Friday nights, there are a lot of people running who are just as new to this as you are! The track officials know this, and are ready to help. If you don't know, ask.
2. If possible, call a few buddies, and go to watch the first time. The spectators entrance is off of Jomax Road (click HERE for directions). Check out the "lay of the land". Ask the racers in the pits how everything works. Remember, everyone there is a car nut just like you, and everyone there was a "first-timer" once themselves. Every time I go, I get asked questions by new guys!
3. When you decide you are ready to give it a try, go to the Happy Valley Road entrance. They will charge you $15 for the car & driver, plus $10 extra for each spectator you bring. You will be given a tech card.
4. Go find a pit space. Only take up one space, as the night goes on, it can get very busy. Unload any loose items in your car (I would suggest you leave what you can at home). Fill out the tech card and sign it. There may also be a space on the back of the card that you must sign, so look there also. Tech is on your way from the Happy Valley entrance to the pits. You will see it on your right. Its a good time to make new friends, and enjoy looking at all the great cars!
5. When tech inspection opens (usually 10-15 minutes after the gate opens) go to the tech area. If you are taking your street car, and it is not a death trap, you will pass tech. Some obvious things you need: seatbelts, safe tires (no cord showing), all lug nuts, radiator coolant overflow catch canister (the factory one is fine), no blatant fluid leaks pouring out, etc! Your battery must be firmly attached to the body of the car (doesn't move when it is pushed on). Also, shorts and tank tops are not allowed! You MUST were long pants while racing! All the officials look for this, so don't try to sneak it by them. This is about it for a street car. If your car runs faster than 13.99, you will need a DOT approved helmet. If you run faster than 11.99, then the entire game changes. However, if your running that well, I'll bet you've been to the track at least a time or two....The tech inspector will write your cars number on the window where it is visible by the timing tower. If staging lanes are not open, then return to your pit.
6. The track announcer will come over the PA system, and say that the staging lanes are open. Listen carefully, as some of the larger tracks have many lanes (Speedworld Motorplex has 8), and they may have cars of different classes report to different lanes. Classes you may want to run in: Test-N-Tune, Street Trophy. The staging lanes go slowly, then quickly, so stay with your car! Also, do NOT run your air conditioner. The condensation on the system will drip down onto the track. This will lead the track operator to believe that there is something wrong with your vehicle. BELIEVE ME, they look for this, and if they see something dripping, then will pull you off the starting line. When they check the liquid on the ground, and see it is plain water, they will chew your butt, and send you to the back of the staging lane.
7. At the end of the staging lanes, there will be a track official. Watch carefully, and when it is time, he will point at you, and then point where he wants you to go. His job is to pair up cars to race, then put them into correct lanes, and also make sure that your seat belt is on, all windows are rolled up. If it is near sundown, turn on your parking lights. Having at least one working tail-light is a required rule at all tracks. This is how the officials can see where you are on the track. This is so they don't send another pair of cars down the track while you are broke down at the other end. By the way, most tracks make a effort to keep near stock street cars from running sub-10 second race cars. The faster cars will be in the Pro Street and Gambler classes.
8. Since this is for beginners, I will assume you are on street tires. Do NOT drive through the waterbox! Your treaded tires will just pick up water in the treads, and when you do your burnout, it will sling water all over inside the wheel well. You will then track the water all the way down the track, and water will be dripping down onto your rear tires, making them very slick! If you do this, you make the track dangerous for everyone, and you may be asked to leave if you do it again. The water is for slicks, not treaded tires. Drive around the waterbox, then get your car centered in the lane. Back up slightly if needed. There will be another track official to guide you. For street tires, a long burnout is not necessary. Street compounds are hard, and high performance tires are specifically designed to not heat up. Clean off your tires and warm them up with a quick, short burnout.
9. Do not pull up to the tree (the pole with the lights on it)! Every beginner does this. The staging beams are actually about 40 feet or so before the tree! Hopefully, you took my advise and watched the other cars run first, and looked to get an idea where everyone else was pulling up to. If you cant figure it out, don't worry, the starter knows it is "street night", and will help you. When he realizes you cant find the staging beams, watch him. He will walk up next to your car, and motion to you to either pull up, or back. Again, don't get embarrassed, or upset. The starter has to do that several times a night. Slowly pull forward until you see the very top, small yellow light come on. You are now "Pre-Staged". It is considered a racers courtesy to wait for the other car to pre-stage, before staging. Then gently roll forward a few more inches, and the other small yellow light right under the top one will come on. You are now "Staged". Do not roll forward too far, or the "Pre-Staged" light will go out, and you may be required to pull back, to re-light that light. That is called "deep staging", and is usually not recommended unless you are driving your Mother's Yugo. If you do accidentally pull forward too far, and deep stage, do NOT pull back until instructed to do so by the starter. He may just start the tree anyway, and you would be sitting there in reverse! Now, watch the bottom, large yellow light (Not the green or you will be caught sleepin'!)!
10. The starter will activate the tree, and the yellow lights will come on, one at a time .5 seconds apart. When the last yellow light comes on, GO! By the time you react, then your car reacts, the green light will be on. Trust me. If you red light, it is no big deal. Afterward, check your reaction time, and adjust. At Speedworld, a .000 is a perfect light on a standard tree. This is different from other tracks where a perfect light is a .500.(The pros use a tree where all the yellows come on at once, then green.).
11. If you only take one piece of advice from me, please let it be this: Do NOT try to set a national record on your first time out. If this is your first time at the track, PLEASE make at least one pass where you are only running at 80%. This will give you a chance to see what the track feels like, what your car feels like, where the finish line is exactly, where the turn off is exactly. Your senses get overwhelmed when trying something like this the first time. A mistake you would have caught easily any other time can cause you to wreck your car. I've seen excellent drivers wreck great cars from a simple mistake that would have never caught them otherwise. It can happen to you too. This is the most fun you can have with your clothes on, but it is serious stuff too. Treat it that way. Stay in your lane at all costs.
12. Make sure you know exactly where the finish line is! Most new racers brake way too early...the speed trap beams are located 66' BEFORE the finish line beams. Make sure you are not mistaking the speed trap for the finish line!
13. Hopefully, you took my advice, and made your first pass at 80%, so you don't have to worry about figuring out this next section while running flat out....Most tracks have plenty of run out area. Speedworld has something like 1/2 mile of run out area! However, other tracks like North Texas Dragway, as soon as you pass the finish line, you need to get on the brakes. When running the quarter mile, you will be running close to 100 mph at the finish line. If you slam on the brakes at those speeds, it is VERY easy to upset the chassis of the car and loose control, so be careful to not brake too hard.
14. READ THIS SECTION CAREFULLY!!! Before you run, know where the turn off roads are located. Speedworld has 2 turn offs, with one of them located at the very end of the run out area. The turn offs go to the left side of the track and the car in the LEFT lane has the Right Of Way. NEVER, EVER turn in front of another car, crossing their lane!!!! If you are running against a REAL slow car, I will drive all the way to the last turn off, as my only other option would be to sit in my lane and wait for them to finally arrive. I don't like sitting in the middle of my lane on a race track. On another track, several years ago, a street car was running a low 10 second car. The fast car had problems at the starting line, and the street car won. However, the quick car was now on the way. The street car turned in front of the 10 second car which had just cleared the traps at 128mph. A STUPID mistake that can get you and someone else killed! I also saw a kid in a Honda actually miss the first turn off, make a U Turn on the track, and come back to it. I flagged him down on the return road, and let him know that there was another turn off at the end of the track. The officials were also waiting for him at the end of the return road....
15. After you turn off, look for the timing shack, where you can pick up your time slips. It is located on the left side of the return road, across from the Tech entrance. When they hand you your time slip, DO NOT READ IT YET! Wait until you are back to your pit to do that, for right now, you need to get out of the way! Continue back up the return road (the posted speed limit is 10 mph in the pits). If you want the seasoned people to look down on you, then go roaring around in the pit area. That is also a sure fire way to get asked to leave.
16. CONGRATULATIONS! You just made your first pass down a drag strip! I assure you that you will be hooked after just one time! There is nothing like it...
THINGS TO PACK FOR A DAY AT THE RACES:
1. Pen to fill out tech card
2. 1/4 tank of gas
3. Think about your clothes! It can get pretty cold later at night, or really hot as the day goes on!
4. Sunscreen
5. Helmet (required if your car runs 13.99 or quicker)
6. Fold up chairs
7. Ice chest for drinks and cooling down intake
(GLASS IS NOT ALLOWED!)
8. Cellular phone
9. Bug repellant
10. Orange cones to mark your pit
11. Camera or Camcorder!
12. Long pants are required! If it is hot, consider taking sweat pants you can take off and on.
There you have it. Generally, racers are some of the nicest people around, and like you, they LOVE cars. Ask questions. Ask for advice, and you will get a ton of it. Look for others with cars like yours, and have fun! Most of all, JUST TRY IT!
:cheers: :cheers:
Old Dec 25, 2003 | 02:57 AM
baskin's Avatar
baskin
Default Re: Racing Tips for Beginners - Long (AZCARGASM)
Wow thanks for all the great info!
Old Dec 25, 2003 | 04:03 AM
mcd_57's Avatar
mcd_57
Yeah, I remember the first time I went to the track. My times sucked and I made alot of mistakes. I was concentrating too much on my reaction times and not enough on just driving my car.
That was some great advice. I wish I had been well informed my first time out. It's great that you took the time to write all that out. I'm sure it will help somebody one of these days. That's the kind of stuff we all tend to forget. Good Job. :thumbs:
Old Dec 25, 2003 | 08:12 AM
PJW001's Avatar
PJW001
Default Re: Racing Tips for Beginners - Long (baskin)
:iagree: :iagree: :iagree: :auto:
Old Dec 25, 2003 | 08:30 AM
16Again's Avatar
16Again
St. Jude Donor '07-'12, '20
Nice idea posting that info. :yesnod: Let me add a few things to the list.
1. Be SAFE
2. Have FUN!!!
3. You will meet some of the finest people in the pits. That being said if something is on your mind ASK!!!!! You will receive an answer.
4. HAVE FUN!!!
5. Don't forget to HAVE FUN!!! :lol: Obviously i have fun.......
Bob
Old Dec 25, 2003 | 06:39 PM
billjax's Avatar
billjax
St. Jude Contributor
Default Re: Racing Tips for Beginners - Long (PJW001)
Great writeup!! I haven't gone to the strip yet but I will!!!! :D
Oh my, this is # 500 for me! Not all that much but most of my posts actually contain text!! :lol:
Old Dec 25, 2003 | 06:52 PM
runamuk's Avatar
runamuk
Cruise-In V Veteran
St. Jude Donor '04
Great info :seeya fortunately for me the first time I was able to go racing was when the Forum met in Gainesville last January at the Winter jam :auto:
When I grew up in Phoenix I always wanted to run my car at Firebird but never got the chance :cry and to give away my age a little I went to the winternationals 2 years ina row when they were held at Beeline raceway :leaving:
BTW, how do you like your AE, I hope your enjoying it. :cheers:
Old Dec 25, 2003 | 06:53 PM
LittleBoyBlu99's Avatar
LittleBoyBlu99
:cheers: :thumbs: Always think safety 1st.
Old Dec 25, 2003 | 09:51 PM
MC TORCH RED's Avatar
MC TORCH RED
Default Re: Racing Tips for Beginners - Long (LittleBoyBlu99)
great info. :thumbs:
Old Dec 25, 2003 | 10:11 PM
Monster231's Avatar
Monster231
Default Re: Racing Tips for Beginners - Long (MC TORCH RED)
On a bad pass always remember, you can either save the pass, or save the car, let it go :iagree: :thumbs:
Old Dec 28, 2003 | 09:22 AM
V8_Club's Avatar
V8_Club
Default Re: Racing Tips for Beginners - Long (Monster231)
Excellent Info. :thumbs: Thanks.
P.S. This might sound stupid but I have never done a burnout in my life . :banghead: What is the best way to do one with an A4 ?
Old Dec 29, 2003 | 01:37 AM
markcz's Avatar
markcz
Default Re: Racing Tips for Beginners - Long (V8_Club)
:lurk:
Old Dec 29, 2003 | 02:29 AM
Lancer033's Avatar
Lancer033
great info, wish i would have had that a few months ago
Old Dec 29, 2003 | 08:01 AM
Jason's Avatar
Jason
CI 4-5-6-7 Veteran
Mash brake. Mash gas.
Old Dec 29, 2003 | 08:20 AM
Patches's Avatar
Patches
Awesome writeup, man. Here's a :thumbs: and a :cheers: to you!
:auto: :steering:
Old Dec 29, 2003 | 08:46 AM
V8_Club's Avatar
V8_Club
Default Re: Racing Tips for Beginners - Long (03Ragtop)
:banghead: Thanks. No need to set the parking brake ?
Old Dec 29, 2003 | 09:12 AM
Jason's Avatar
Jason
CI 4-5-6-7 Veteran
Nope.
To Racing Tips for Beginners - Long
Old Dec 29, 2003 | 09:24 AM
V8_Club's Avatar
V8_Club
Thanks. :hurray: :hurray:
Old Dec 29, 2003 | 09:26 AM
Jason's Avatar
Jason
CI 4-5-6-7 Veteran
Oh yeah, don't forget to turn off traction control. :thumbs:
Old Dec 29, 2003 | 10:09 AM
V8_Club's Avatar
V8_Club
:thumbs: :steering:
