It runs rougher! I was getting a little missing and stumble on low rpm lugging conditions. It would cough sometimes at low rpm WOT to. The idle was much rougher and the overall the engine ran a little ragged and would start to break up and miss over 5000 rpms sometimes.
The #7 plug wire was on the plug, but not pushed home to "click" on like when it fully seated. It just fell off the plug with no pulling.
I changed plugs anyway even though the TR 55 with 10K on them looked perfect and the gap was still .055. I used some stock Z06 Denso platinum plugs that I had laying around, gapped them at .050. It all took me 3 hrs. I am embarrassed to say!
The stock plug wires and heat shields were in perfect shape, even though they come close ( almost touching) to the FLP headers, but there was no heat damage at all. I reused them. I really pulled on them hard to get them off, but they still work fine.
Engine runs much smoother and stronger. Next time I will check the wires before I change the plugs!
Re: How the engine runs with a Plug wire loose (Mike Mercury)
Mike, I only have used the 2 types of plugs, TR55's and the Denso stock Z06 plugs. Honest, I could not tell a difference between them by butt dyno. Like yourself, I spent years in the old days, "reading" plugs to analyse engine performance etc. The TR55's were perfect condition and just the right color etc, on my car at 10K miles, I would guess they would easy go double that.
I only put in the platinum Denso's because I figured I could get more miles on them before they wear out! I would love to see a back to back real dyno, I bet the TR55 old style plugs would win by about 3 to 5 hp.
