Tire Pressurs Sensor Error
Old Dec 27, 2003 | 10:17 PM
IrishMac's Avatar
IrishMac
Moderator Emeritus
Gone, but not Forgotten
Cruise-In 5, 6, 8 & 10 Veteran
St. Jude '03-'04-'05-'06-'07-'08-'09
Default Tire Pressurs Sensor Error
I'm getting a DIC error message saying "Service Tire Pressure Sensor" (or something like that) from the left rear. I searched the archives and found some good info on this, but have a question.
Can I retrain just the bad sensor, or do I have to do all four. Also, how do I know it just isn't a bad battery?
Thanks folks :thumbs:
Old Dec 27, 2003 | 10:57 PM
rhoeven's Avatar
rhoeven
Default Re: Tire Pressurs Sensor Error (98BlackMagic)
No, you can't. If you replace one sensor, you have to train them all as instructed by the training procedure on the DIC. It's not a big deal
Roger :cheers:
Old Dec 27, 2003 | 11:32 PM
IrishMac's Avatar
IrishMac
Moderator Emeritus
Default Re: Tire Pressurs Sensor Error (rhoeven)
Roger :cheers:
Thanks for the info. Is there any waya to tell if it's the battery? :confused:
Old Dec 27, 2003 | 11:46 PM
C5 StockSwap's Avatar
C5 StockSwap
Cruise-In V Veteran
St. Jude Contributor
I'd give it a day or two...may have only lost communication and it may re-establish itself. You could also go through the relearn process, and if you get to that wheel and it won't relearn, you probably have a bad battery. No other way to tell.
Old Dec 28, 2003 | 12:59 AM
You will have to do all four, but it is a simple procedure. If that doesn't work, then perhaps the sensor itself is bad.
To Tire Pressurs Sensor Error
