What gears and torque converter?
Old Dec 30, 2003 | 10:45 AM
sjk103098's Avatar
sjk103098
Default What gears and torque converter?
I have an 03 coupe that is a4 what would be the best gears and t/c to get for this...what is going to the benefit of these. thanks :thumbs:
Old Dec 30, 2003 | 10:58 AM
WestCoastCorvette's Avatar
WestCoastCorvette
Supporting Vendor
Default Re: What gears and torque converter? (sjk103098)
sjk103098
I would have to say either the 3.42 or 3.73 gear. It all depends upon what you are going to do with the car. Are there any power adders your gouing to use,(ie) nitrous, supercharger,heads and cam.
Old Dec 30, 2003 | 11:45 AM
Mitch C's Avatar
Mitch C
Default Re: What gears and torque converter? (WCC PAUL)
To determine what T/C and gearing combo is best, we would have to know what are your plans for your car?
1) Do you plan on racing your car often?
2) What kind of tires are you planning on running?
3) Do you drive alot on the highway?
4) How important is driveability to you?
Old Dec 30, 2003 | 02:30 PM
sjk103098's Avatar
sjk103098
Well, I would probably decline on the nitrous, but as far as s/c or the heads and cam that would be and possible. I would basically be using the car as a go fast car, when I would want to, witha car like this I would like to make it to the track, but i'm not real sure how to get the c5 ready for it. thanks :thumbs:
Old Dec 30, 2003 | 03:38 PM
AF-Vette's Avatar
AF-Vette
The 3.42 gears are great if you want to maintain highway cruising capability (about 2200 rpm @75 mph and still get 24mpg). If you go with the 3.73's you will gain a little in the 1/4 mi but long distance highway cruising will be a pain. I didn't go with a converter but I know several who did with mixed results. If you plan on doing the 1/4 mi regularly, do it. If not, spend your money on a good set of long tube headers.
Old Dec 30, 2003 | 07:24 PM
Mitch C's Avatar
Mitch C
1) If your motor is N/A stock or with H/C = SS3600 or SS3800 and 3.42 or 3.73 gears.
2) If you have a S/C = The Yank PYE3400 or PYE3600 and 3.42 gears.
Old Dec 30, 2003 | 07:35 PM
Cary's Avatar
Cary
Default Re: What gears and torque converter? (AF-Vette)
:iagree: As long as my C5 is a daily driver I'm staying with the factory TC. However, real :D with my 3.42 rear diff & Pro LG LT Header system :yesnod:
Old Dec 30, 2003 | 07:49 PM
gojo's Avatar
gojo
Don't be afraid of a converter. Match it with gears and it will tighten up. I guarantee you will want a converter later.
I like the SY3500 for a daily driver. :steering:
Old Dec 30, 2003 | 07:55 PM
Cary's Avatar
Cary
Default Re: What gears and torque converter? (jfpilla)
Hey jfpilla,
Does you 03 Vert have 3.42 rear?
- Cary
Old Dec 30, 2003 | 10:15 PM
gojo's Avatar
gojo
Default Re: What gears and torque converter? (Cary)
I had a 3.42 and SY3500. The were great for a daily driver. I'm getting more serious so I now have a PT4000 and 3.90.
Old Dec 31, 2003 | 09:39 AM
BayouVette's Avatar
BayouVette
i think if your gonna make it a go fast car I would do it right the first time. But I think the 3.42s are perfect for any application. You should get the ST3500 it is hard hitting off the line. The SY3500 actually has a lower STR than stock. If your making it a go fast car I'd assume you wont be on street tires so I would definitely get the ST3500
Old Dec 31, 2003 | 11:22 AM
BHP's Avatar
BHP
I have studied this and driven a few cars. The 2:73 and 3:15 gears are not enough IMO. Mininmum is 3:42 and is the best if you are doing street and freeway driving. Street and drags, 3:73+. TC is fine if you have the right tires otherwise you will smoke the stock EMTs. For mixed driving I would stay with stock TC and go with 3:42 but it looks like you will want more than that based on future mods.
[Modified by BHP, 8:23 AM 12/31/2003]
To What gears and torque converter?
