No Stop lites/tail lites
Old Dec 31, 2003 | 01:03 PM
uwant1's Avatar
uwant1
Default No Stop lites/tail lites
I have no stop lite,or taillites,and went I turn the alarm on it go off, I hav euro taillites, and they been on the car for almost for years, the car had been parked for over a month. Went I drove it last saturday the alarm went off went I tryed to set it. went I go home I saw that I had no taillites or brake lites. Can someone help.
Old Dec 31, 2003 | 01:20 PM
2KVetteMan's Avatar
2KVetteMan
Default Re: No Stop lites/tail lites (uwant1)
I suspect the Euro Taillights is the culprit. Same thing happen to me, except without the alaram going off.
Like some on this forum the harness that you have on your EuroTaillights could be a loose wire. Check your harness, unplug it, look at the wires and see if you see any loose. Most of the case like myself its not visible to the eye. I always unplug my harness give it a nice wiggle and zipped tied it in place. If your harness can move around secure it down.
You should see your taillights working again.
I just jacked my rear up and disconnected the harness and plug it back in and zipped tied it in place and its been good ever since. :cheers:
Old Dec 31, 2003 | 01:31 PM
Shinobi'sZ's Avatar
Shinobi'sZ
Default Re: No Stop lites/tail lites (2KVetteMan)
Before you do anything pop out the fuse and make sure it is not blown. I blew a fuse once on the track when the ABS kicked in....my tail lights and brake lights quit working....and it was the fuses.
Old Dec 31, 2003 | 03:41 PM
tomdcarguy's Avatar
tomdcarguy
From: A.M.R. Pound for Pound-Fastest Stock Bottom LS1 9.1x 10psi
Check for a bad conection in the "euro" harness in the right rear wheel well. turn lights on and wiggle the harness. Good chance you'll find a bad connection from a stretched or pulled wire.
Old Dec 31, 2003 | 04:40 PM
uwant1's Avatar
uwant1
Thanks (2KVetteMan) I tryed the same thing you did, and it worked. And thanks to everbody for helping.
And I hope Everone a "Happy New Year."
Old Dec 31, 2003 | 11:07 PM
2KVetteMan's Avatar
2KVetteMan
:flag :cheers:
Very cool. Glad to see it was nothing serious. Glad I can help, that why this forum rocks. Everyone have a safe new year.
To No Stop lites/tail lites
