Battery Tender Neg Clip?
Dec 31, 2003 | 01:39 PM
Are you guys connecting your negative alligator clip to the engine block or to the negative on the battery? I am using the battery tender plus and just attached mine to the block as a ground.
Dec 31, 2003 | 01:56 PM
Re: Battery Tender Neg Clip? (MCD99FRC)
I have been attaching right to the battery.
Stan
Dec 31, 2003 | 02:25 PM
Cruise-In III Veteran
Cruise-In V Veteran
St. Jude Donor '03-'04
Re: Battery Tender Neg Clip? (Stan47)
Stan
:iagree:
Dec 31, 2003 | 02:41 PM
Stan
:thumbs: :cheers:
Dec 31, 2003 | 03:35 PM
Battery...................for the last 4 years. :yesnod:
Dec 31, 2003 | 03:52 PM
Same here. Sometimes it's difficult to get a good ground elswhere.
Dec 31, 2003 | 04:21 PM
Re: Battery Tender Neg Clip? (Patches)
I attach mine to the battery. :party:
Dec 31, 2003 | 05:00 PM
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18- '19
TTB To The Battery :D
Dec 31, 2003 | 05:09 PM
Re: Battery Tender Neg Clip? (vette#one)
:iagree:
Dec 31, 2003 | 05:17 PM
Re: Battery Tender Neg Clip? (rodknock)
Both my pos and neg battery tender cables are hard wired to the battery with a quick-disconnect for the battery tender 3 feet from the terminals. I just plug the tender into the quick-disconnect and walk away..
Jan 1, 2004 | 09:09 AM
St. Jude Donor '06-'07
Battery.... :yesnod:
Jan 1, 2004 | 01:18 PM
Cruise-In VII Veteran
Re: Battery Tender Neg Clip? (BiggieBoy)
Got my neg. lead wired to the battery. :cheers: :yesnod:
Jan 1, 2004 | 01:50 PM
Well the next time I reattach it I will just put it on the battery a little more covienient and easier to get a ground. Thanks For The Response.
Jan 3, 2004 | 12:45 AM
Mine is attached to the negative post on the battery.
Jan 3, 2004 | 08:50 AM
From: Making my carbon footprint as BIG as possible
Cruise-In IV Veteran
St. Jude '03-'04-'05-'06
Re: Battery Tender Neg Clip? (JDs00PewterCoupe)
:withstupid: :yesnod:
Jan 3, 2004 | 11:41 AM
Re: Battery Tender Neg Clip? (ChrisLe)
:iagree:
3 years hard wired - no problems and car is covered with a car cover!
Mordi
Jan 3, 2004 | 01:39 PM
I bought the adaptor that plugs into the cigarette lighter. I have two spare sets of clip style connector harnesses
Jan 3, 2004 | 02:45 PM
I attach mine to that metal tab that sticks up off the water pump.
The reason it's not recommended to attach to the negative battery terminal is because that connection can cause a spark. If there is any battery gas leakage it could cause an explosion. You can probably get through an entire life-time without that happening. But it only takes once.... :cheers:
