Blower Motor Noise?
Old Jan 1, 2004 | 12:39 AM
Corvette ED's Avatar
Corvette ED
From: Pottsville, PA. USA Home Of America's Oldest Brewery Yuengling
Default Blower Motor Noise?
2000 model with dual zone when the heater or A/C is on the blower fan makes noise. Has anyone had this problem? What is the fix?
[Modified by Corvette ED, 12:40 AM 1/1/2004]
Old Jan 1, 2004 | 12:47 AM
Tsab's Avatar
Tsab
Default Re: Blower Motor Noise? (Corvette ED)
Mine make noise as well, I'm interested as well. :lurk:
Old Jan 1, 2004 | 12:53 AM
Z06 Mike's Avatar
Z06 Mike
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
Default Re: Blower Motor Noise? (Tsab)
Oh...THAT blower. :smash: :smash: :smash: :lol: :lol: :lol:
Old Jan 1, 2004 | 01:29 AM
LittleBoyBlu99's Avatar
LittleBoyBlu99
Default Re: Blower Motor Noise? (OCMike)
:lol: :lol: :lol: :thumbs:
Old Jan 1, 2004 | 01:32 AM
MC TORCH RED's Avatar
MC TORCH RED
Default Re: Blower Motor Noise? (LittleBoyBlu99)
mine did it for a short time then stopped.............. :confused:
Old Jan 1, 2004 | 02:41 AM
3RD-INF's Avatar
3RD-INF
mine does it, but only when the heater is running. the dealer said he couldn't hear it. :nopity guess i'll have the wife fix it.
Old Jan 1, 2004 | 03:11 AM
MC TORCH RED
Default Re: Blower Motor Noise? (3RD-INF)
:iagree: she's most likely smarter than the dealer :yesnod: :lol: :lol:
Old Jan 1, 2004 | 03:23 AM
LoneStarFRC's Avatar
LoneStarFRC
Default Re: Blower Motor Noise? (MC TORCH RED)
I know that's right! :lol: BTW, if I'm not mistaken, it gets replaced from inside the car in case it comes to that. Robert
Old Jan 1, 2004 | 01:00 PM
AF-Vette's Avatar
AF-Vette
You might want to check if your A/C condensation drain line is blocked/kinked. It is located on the firewall on the passenger side (relatively easy to see from the bottom). If this line is blocked, water builds up in the fan area and eventually the fan starts hitting it and making noise.
Old Jan 1, 2004 | 02:58 PM
Kenny94945's Avatar
Kenny94945
Even a tiny pine needle can make a noise if it enters the blower box.
One needs to be a little limber, but it is easy to remove the box from under the pass. dash. Note the position of the rubber tube and a seal on the top. Also I recall one electrical connector & three nuts.
Then look for debris between the fan and box. Clean it out and re-assemble. They may be a procdure in the search history.
Happened to me a couple years ago.
Old Jan 4, 2004 | 07:02 PM
Corvette ED
Default Re: Blower Motor Noise? (Kenny94945)
Thanks for the help. I did a search and it was helpfull.
Old Jan 5, 2004 | 12:50 AM
jmX's Avatar
jmX
The bearings in the old blower motors kinda sucked and apparently failed on a few peoples cars, including mine (at first I thought it was leaves, but upon inspection it turns out it was the bearing).
Anyway, it cost like $100-$200 (cant remember) at most to buy the part, and it took me maybe half an hour to replace it. Its held in with something like 3 hex head screws, and drops right out from under the passengers side of the dash. SIMPLE!
I was going to do a "howto" on it, but it turned out to be too easy to make it really worthwhile.
Jon
http://www.ls1howto.com
To Blower Motor Noise?
