Performance axle ratio???
Old Jan 3, 2004 | 11:01 AM
Dave-T's Avatar
Dave-T
Default Performance axle ratio???
I am looking at used C5's with automatic transmissions. How do I tell if it has the performance axle ratio?
Old Jan 3, 2004 | 11:45 AM
Killrwheels's Avatar
Killrwheels
Default Re: Performance axle ratio??? (Dave-T)
G92 - 3.15 rear on auto's
Old Jan 3, 2004 | 12:00 PM
blktie8's Avatar
blktie8
on the glovebox door look for g92 option
Old Jan 3, 2004 | 01:11 PM
Mike Mercury's Avatar
Mike Mercury
Default Re: Performance axle ratio??? (blktie8)
a few methods here:
Determine your C5 A4 rear axle ratio
[Modified by Mike Mercury, 1:20 PM 1/3/2004]
Old Jan 3, 2004 | 08:34 PM
1g1yy's Avatar
1g1yy
Default Re: Performance axle ratio??? (Mike Mercury)
If it won't turn the wheels over hardly at all -- it has 2.73's! :cheers:
Old Jan 4, 2004 | 01:26 AM
REDGAR's Avatar
REDGAR
Cruise-In II & IV Veteran
CI VI Drag Champ!
Dave good luck with your search.
Old Jan 4, 2004 | 02:48 AM
MC TORCH RED's Avatar
MC TORCH RED
Default Re: Performance axle ratio??? (REDGAR)
good luck , when you find one the 2.73's or 3.15's won't be enough. 3.42 or 3.73's is what you will want soon. :yesnod:
Old Jan 4, 2004 | 09:31 AM
Dave-T's Avatar
Dave-T
Default Re: Performance axle ratio??? (MC TORCH RED)
Yeah. I plan on going with 3.73's. Does it make a difference on ease or cost of upgrade to the 3.73's if you have 2.73's or the 3.15's. I am guessing it does not since they are both Dana 44's. Is this correct.
Old Jan 4, 2004 | 03:21 PM
REDGAR's Avatar
REDGAR
CI VI Drag Champ!
Dave I am pretty sure the 2.73 is a defferent case and cannot be rebuilt to be a different gear.
A 3.15 uses the same case as the taller gears so you can have it rebuilt to the gear you want.
If you are going to buy new 3.73s the the 2.73 will make you feel better when you spend the mone cause it is a bigger jump;)
If you are going the rebuild route, get the 3.15.
I think the rebuild route is a little less expensive.
Old Jan 4, 2004 | 04:50 PM
J Z06's Avatar
J Z06
Good luck Dave. C5's are VERY nice. :cheers:
Old Jan 4, 2004 | 05:04 PM
Old Rotor Head's Avatar
Old Rotor Head
Default Re: Performance axle ratio??? (1g1yy)
Old Jan 4, 2004 | 08:29 PM
Mike Mercury
That was the case; but recently a forum vendor (I can't remember who) can re-gear the 2 series case... but they're the only source that I know of.
Old Jan 5, 2004 | 02:31 AM
TGKx's Avatar
TGKx
that would be DTE http://www.dynotech-eng.com/
good prices too :smash:
To Performance axle ratio???
