HELP!!ANYBODY HAVE THIS PROBLEM?
Old Jan 4, 2004 | 01:35 AM
Southview's Avatar
Southview
Default HELP!!ANYBODY HAVE THIS PROBLEM?
I have an 01 vert with 12k miles.I have only had the car for 2 months.I put on a cold air intake and didn't notice before but when letting off the gas the car feels like it is hesitating/stumbling(like something is holding it back then speeding it up).I have put 1k miles on it since the intake was changed.I have no trouble codes or decreased gas mileage.The car idles smooth and drives smooth at most speeds but when I let off the gas it startsacting weird.Is this normal and maybe didn't notice before?The intake is a Granatelli cold intake not some cheap Ebay junk.Any opinions? :confused:
Old Jan 4, 2004 | 08:16 AM
vetterdstr's Avatar
vetterdstr
CA Events Coordinator
Default Re: HELP!!ANYBODY HAVE THIS PROBLEM? (Southview)
Just for kicks, take that new part and put the stock parts back on. If it goes away... dont put back that intake and modify your stock box by opening up the cover and installing a K&N filter instead. No sense on going through problems just to keep a single part on the car...it's just not worth it. :nono:
VR :cheers:
Old Jan 4, 2004 | 08:30 AM
runamuk's Avatar
runamuk
Cruise-In V Veteran
St. Jude Donor '04
:confused: thats a new one on me, usually they hesitate when stepping on the gas not letting off, but I agree with Vettrdstr first remove the latest part you added and see if that has any affect. :cheers:
Old Jan 4, 2004 | 11:37 AM
vetterdstr's Avatar
vetterdstr
Default Re: HELP!!ANYBODY HAVE THIS PROBLEM? (runamuk)
My car is in the shop right now for hesitating while rolling on the gas and coming off as well as surging while driving at freeway speeds with the cruise control on. Using a Tech II to check the drive by wire system is what we are looking into and replacing 2 sensors and the Gas pedal unit if needed. Been doing it for years now... 770 FWHP only magnifies the problem... :)
VR :cheers:
Old Jan 4, 2004 | 02:18 PM
V8_Club's Avatar
V8_Club
Default Re: HELP!!ANYBODY HAVE THIS PROBLEM? (vetterdstr)
VR :cheers:
:crazy: Those a crazy numbers. :cheers: .
This maybe your problem. My opinion since it doesn't do it while flooring it forget it. :lol: It might want to keep at when you let go :lolg: .
Old Jan 4, 2004 | 02:34 PM
georgec114's Avatar
georgec114
Yep...My 01, A4, 315 has done this from day 1...With or without
Blackwing. It is more noticeable if using 3rd gear (D3).
I've read others have had this "feature" as well.
Hasn't bothered me at all, but does feel a little wierd at times.
...George
Old Jan 4, 2004 | 04:28 PM
runamuk's Avatar
runamuk
Cruise-In V Veteran
St. Jude Donor '04
VR :cheers:
I only wish I had that problem :crazy: :cheers:
Old Jan 5, 2004 | 12:11 AM
MC TORCH RED's Avatar
MC TORCH RED
:iagree: 700hp :eek:
Old Jan 5, 2004 | 12:32 AM
steponc's Avatar
steponc
St. Jude Donor '14
I have all Granatelli parts and had the same problem. I found a crack in the seam of the air bridge. I would check all connectin points for possible air leaks.
Old Jan 5, 2004 | 11:27 AM
Southview's Avatar
Southview
Default Re: HELP!!ANYBODY HAVE THIS PROBLEM? (steponc)
What is the easiest way to check for a leak?I tightened all the clamps to make sure it wasn't leaking before I posted,but I didn't think about the air bridge.If I blow compressed air around the air bridge will it tell me anything?
Old Jan 5, 2004 | 01:54 PM
vettatude's Avatar
vettatude
Default Re: HELP!!ANYBODY HAVE THIS PROBLEM? (georgec114)
Same here. Almost seems like a A4 problem, TC or something.
Old Jan 6, 2004 | 09:30 PM
SQEZN BI's Avatar
SQEZN BI
I noticed this after i changed my gears , it only does it when im in between gears and the rpms get real low it feels like the car is missing . might not be the same problem.
Old Jan 7, 2004 | 10:03 AM
tabbruzz's Avatar
tabbruzz
What cold air intake do you have?
Old Jan 7, 2004 | 01:44 PM
Southview's Avatar
Southview
Default Re: HELP!!ANYBODY HAVE THIS PROBLEM? (tabbruzz)
Granatelli Super ram cold intake
Old Jan 7, 2004 | 09:29 PM
DIAMOND DAVE's Avatar
DIAMOND DAVE
Just spray a little starting fluid or either around the intake connections and if it is leaking it should pick up a faster idle speed.
To HELP!!ANYBODY HAVE THIS PROBLEM?
