LS1 vs. LS6 block???
Old Jan 4, 2004 | 01:05 PM
Bone_Stock's Avatar
Bone_Stock
Default LS1 vs. LS6 block???
What are the differences as far as horsepower. I've heard they have a few more ponies than just the LS1. Why is this? Is the LS6 stronger as well? :jester
Old Jan 4, 2004 | 01:41 PM
V8_Club's Avatar
V8_Club
Default Re: LS1 vs. LS6 block??? (Bone_Stock)
For years '02+ The difference is around 50-55 Cran ponies.
This can be attributed to :
1- Open Intake Port ( actually little more than current C5 )
2- Better Heads
3- Lighter Valve Train
4- More aggressive cam
5- Better Short Block
6- May be the TI exhaust :skep:
That is about it.
Old Jan 4, 2004 | 01:56 PM
Bone_Stock's Avatar
Bone_Stock
Default Re: LS1 vs. LS6 block??? (V8_Club)
I was just refering to the shortblock. I guess I should have made myself clear. I think it was something to do with the oiling system.
Old Jan 4, 2004 | 02:41 PM
V8_Club's Avatar
V8_Club
OK. The LS6 block incorporated bulkhead windows which allowed better crankcase breathing between bays & resulted in decreased crankcase pressure. :seeya
Old Jan 4, 2004 | 03:15 PM
kewlbrz's Avatar
kewlbrz
Cruise-In II Veteran
Cruise-In III Veteran
In the C5 at least. Beginning in late 01. All LS1 and LS6 share the same block.
Old Jan 4, 2004 | 07:51 PM
WhiteDiamond's Avatar
WhiteDiamond
St. Jude Donor '15
Default Re: LS1 vs. LS6 block??? (kewlbrz)
Even though the blocks where shared heavily(typically, LS1 spec'd vehicles got an LS6 block), the LS6 block I believe still only got the additinal machining to open the bay to bay windows more when built on the LS6 line. The LS6 block is cast from a stronger material, but I have heard a few vendors like the LS1 block for resleeving...
Todd
Old Jan 4, 2004 | 11:05 PM
kewlbrz's Avatar
kewlbrz
Default Re: LS1 vs. LS6 block??? (BLK 98WS6)
Todd
c4c5specialist (gm dealer tech) on here quite a while back, confirmed the bay to bay breathing windows in late 01+ C5 LS1's that he has disassembled for various reasons.
Jason Squires on here also had this to say in a late 01 post here:
"F.Y.I. During a tour of the St. Catherines, Ontario GM Engine Plant (where our C5 engines are built) we learned that our LS1 block will be replaced by the LS6 block."
Part numbers are also shared as well.
To LS1 vs. LS6 block???
