where to get correct valve spring shims?
Old Jan 6, 2004 | 08:25 PM
vettemaster1's Avatar
vettemaster1
Default where to get correct valve spring shims?
hi, does anyone know where to get valve springs shims that are made for ls1? :seeya
Old Jan 7, 2004 | 07:09 AM
lowdowndirty's Avatar
lowdowndirty
Default Re: where to get correct valve spring shims? (vettemaster1)
Any one of the supporting tuners that do head work will probably know part numbers right off the top of their head. However, it would be just as easy to go to a reputable auto. machine shop and pick some up. This is, of course, if you have already measured the installed heights and know what thicknesses you need. If the heads are apart and off the vehicle, and you either don't have a height mic or aren't completely sure of the method, take the heads, valves, springs, retainers and locks to the shop and let them install the valves for you. Good luck. Chris.
