30K Service Advise
Old Jan 6, 2004 | 09:17 PM
Abnsteel06vette's Avatar
Abnsteel06vette
Default 30K Service Advise
I dropped my car off at the dealer to fix my fuel gage. He offered the 30,000 mile service to me. The car only has 26000 miles so I indicated that I would wait. What I really want to know is if that service is really worth it. He indicated that they open the transmission and change the fluids. I have heard many mechanics who advise not to fool with the transmission if it is not given a problem. The service mananger also indicated all the stuff that is done to the car. many i do not need because I have done them recently. ie tire balance, blackwing filter etc. Transmission and coolant I have not done. Any advise would be helpful. He indicated that automatic transmission and coolant change would be 270.00 dollars. Thanks
:confused: :flag :nonod: :banghead:
Old Jan 6, 2004 | 09:30 PM
robsvette's Avatar
robsvette
Default Re: 30K Service Advise (Abnsteel06vette)
too much money!!! do it urself!
Old Jan 6, 2004 | 10:20 PM
bowtiebandit's Avatar
bowtiebandit
270.00 seems a little steep for that, did he explain what exactly they where going to do?
Our Trans services our 79 and some change and coolant change is under 75.
Now we also offer trans' flushes which jumps the price up but it does include up to 16 quarts of trans fluid and yes it does change all the fluid in the system.
Did they also give you a break down of what the 30k includes?
Old Jan 6, 2004 | 11:06 PM
Stock Man's Avatar
Stock Man
2015 C5 of Year Finalist
St. Jude Donor '05-'06-'07-'08-'09-'10
Default Re: 30K Service Advise (bowtiebandit)
Your tranny fluid should be good for at least 50k. The coolant and hydraulic fluids should be changed every two years under normal driving conditions. My .02 :thumbs: :seeya
Old Jan 6, 2004 | 11:40 PM
KKu77's Avatar
KKu77
Default Re: 30K Service Advise (Stock Man)
:iagree: Also, you may want to look at changing out the fuel filter out if you hadn't already
Old Jan 7, 2004 | 12:30 AM
MC TORCH RED's Avatar
MC TORCH RED
Default Re: 30K Service Advise (KKu77)
:iagree:
Old Jan 7, 2004 | 09:50 AM
Duck916's Avatar
Duck916
Read the manual. It says what you need to do at this point. Don't go by what the dealer suggests, as the dealer's goal in this case is to make money. (Big surprise.)
Old Jan 7, 2004 | 04:51 PM
fdxpilot's Avatar
fdxpilot
Default Re: 30K Service Advise (Duck916)
:iagree: They are just after your bucks!! If you've been changing your oil in accordance with the DIC or more often and changed the air filter (Yea, Blackwing), there is no scheduled maintenance. You might want to check your plugs, as the factory Delcos have a history of losing electrode pucks, but your fluids should still be good. :auto:
[Modified by fdxpilot, 3:53 PM 1/7/2004]
Old Jan 7, 2004 | 07:36 PM
Abnsteel06vette
Default Re: 30K Service Advise (fdxpilot)
I checked the manual and it indicated that it would be at 50K...thanks
Old Jan 7, 2004 | 07:38 PM
Abnsteel06vette
bowtiebandit
Where are you located in Maryland, I am in alexandria. I plan to do all this when the car hits 50K. Maybe I can take it to your shop.
Old Jan 8, 2004 | 12:05 AM
bowtiebandit
Fox Chevrolet in Laurel..going on 17 years in May :cheers:
To 30K Service Advise
