160 degree thermostat???
Old Jan 7, 2004 | 02:51 AM
DelMonteZO6's Avatar
DelMonteZO6
Default 160 degree thermostat???
I am ordering a 160 degree thermostat... Your thoughts??? Good Move? Bad Move??.
Old Jan 7, 2004 | 04:17 AM
LittleBoyBlu99's Avatar
LittleBoyBlu99
Default Re: 160 degree thermostat??? (DelMonteZO6)
172 or 178 would be better" just my 2 cents. :thumbs: :cheers:
Old Jan 7, 2004 | 06:28 AM
There was a thread on this not too long ago. Seemed like the general feeling was that perhaps a 160 was too cool for the car and that a little warmer temp was better. Do a search and see if you can find the original thread.
Old Jan 7, 2004 | 08:09 AM
BSiegPaint's Avatar
BSiegPaint
St. Jude Donor '06-'07
It won't do anything for you unless you also change the temps at which your fans come on (for anything other than highway driving). I haven't seen anyone actually post figures on performance gains (or losses) from using colder thermostats, though I have always understood that colder engines run "better". I don't know enough about the LS1 to make that determination. I am running a 160 thermo and my fans come on at a lower temperature. My engine rarely gets above 190°, and runs a constant 171° on the highway. No issues with the heater, etc. even in this freezing cold weather in Cleveland. I haven't noticed any real benefit to this set-up, only cooler temps. :cheers:
Old Jan 7, 2004 | 09:54 AM
DelMonteZO6
Default Re: 160 degree thermostat??? (BSiegPaint)
Yeah I was told by the Chevrolet mechanic 160 is the way to go. He said bottom line performance or not, the cooler your engine runs, the longer it will live. What program did you use to change your fans? And what do you have them set to? I think they are set to 230 degrees from factory. Ive never had a car in my life that ran that hot.
Old Jan 7, 2004 | 10:18 AM
Evil-Twin's Avatar
Evil-Twin
St. Jude Donor '03-'04
the 160 is too cold for the winter... but the 160 is great for the summer... I change mine from the stock 190 to the 160..in the spring... takes me five minutes to make the swap... I also have a vinci fan controler to adjust my fan settings..
Old Jan 7, 2004 | 11:17 AM
DelMonteZO6
Default Re: 160 degree thermostat??? (Evil-Twin)
Ok so lets say I put in the 170 degree... I looked at the Vinci fan controller and I like it. What would I want to set my fans at? Im thinkin like 180?? And has anyone tried that little hot water bypass thing for 20 bukcs to make the hot water flow away from the throttle body to keep lower air temps??
Old Jan 7, 2004 | 11:40 AM
ArKay99's Avatar
ArKay99
I have a 160 in mine. I agree that it is somewhat cold for the winter, especially in NJ. The heater still cranks, but the car never goes above 170 when idling and stays at 160 on the highway. I'm leaving mine in for now, 'cause I don't do that much driving in the winter in NJ, in my vette. I set my fans to the 160 degree setting on a Hypertech. I have read that the LS1 makes the most power at 180 degrees. The oil is thin enough at that temp and the engine is still cool enough to make good power, so the combo works at about 180 degrees. If you are going to do some racing in the spring and summer, I would put a 160 in then, and use a 172 or similar in the winter. But as stated above, you will have to change your fan temps when doing that.
I have the coolant bypass installed. It doesn't do anything as far as I can tell, and in the winter you probably want to keep your TB warm to keep it from icing in cold wet weather. Again, you might want to put this in in the spring when you change to a colder thermostat. :steering:
[Modified by ArKay99, 11:42 AM 1/7/2004]
Old Jan 7, 2004 | 05:22 PM
FKING1's Avatar
FKING1
Default Re: 160 degree thermostat??? (ArKay99)
Have 178 stat , Vinci Controller which I actually didn't need as my tuner reset fans with software. 1st fan on at 191 off at 183. 2nd fan on at 204 off at 193. Car runs at about 183 summer and 178 Detroit winter.
Fred K.
Old Jan 7, 2004 | 05:39 PM
Pumba's Avatar
Pumba
DelMonteZ06,
I have a 160 degree F thermostat in my Z06. I had my engine tuner - Detroit Speedworks - set my cooling fans to come on at 185 degrees F.
My Z06 runs down the road at about 172 degrees F with the 160 degree F thermostat. If you drive your car in the winter, then the 160 degree F thermostat is too cool. It you store your Z06 over the winter, its the right thermostat.
Good Luck
[Modified by Pumba, 5:40 PM 1/7/2004]
Old Jan 7, 2004 | 05:51 PM
DelMonteZO6
Default Re: 160 degree thermostat??? (Pumba)
Ok...well what I gather is... I drive my car in the winter seldomly but I do. Im thinking I go with a 170 thermostat, set the fans to come on at 190 off at 180. This "I think" with do ok in the winter and summer. It will still be running 40 or more degrees cooler than normal in traffic. And that will put my mind at ease knowing its running much cooler. I hope I am right in this decision. Thank you all for your help.
Oh yeah...and that vinci controller... do you permanetely mount it in your car? Or do you just hook it up for 1 time use?
[Modified by DelMonteZO6, 10:52 PM 1/7/2004]
Old Jan 8, 2004 | 01:36 AM
angryfly's Avatar
angryfly
I have the 170, wish I would have put in the 160. As stated above, I can't really tell the differencewith the coolant bypass.
Old Jan 8, 2004 | 06:58 AM
BT-01-vette's Avatar
BT-01-vette
160 is too cold for the fall and winters! I asked ECS at what temp does your oil have to reach to properly protect your motor and the answer was 150* anything lower than your asking for problems if you run it hard. I was driving around for 20 min in 40* temps (in Sept) with my oil under 150* with the 160* stat. That's too long! Personally IMOP I wouldn't go lower than a 178*. I currently have a 180* stat in there now and that has worked out fine. Summer time I plan to put the 160* back in.
Old Jan 8, 2004 | 09:50 AM
1g1yy's Avatar
1g1yy
Default Re: 160 degree thermostat??? (BT-01-vette)
I put in a 180 degree thermostat and it was the same as the stock one. Many others have found this to be true -- even with the 172 degree stats. If you buy one then before you install it check it in hot water. :yesnod:
I left it in and set my fans to come on a bit sooner with my Hypertech. It now runs at 192 degrees (coolant temp.). It never runs above 208. A GM mechanic told me that was about optimum! ( No two will tell you the same thing.)
:rolleyes:
Old Jan 8, 2004 | 09:52 AM
blue1999vette's Avatar
blue1999vette
Cruising
i installed the 160 years ago on my vette, my girlfriend had the same year vette, it took a lot longer for the interior to get warm in the winter compared to hers
Old Jan 8, 2004 | 01:22 PM
FKING1's Avatar
FKING1
Default Re: 160 degree thermostat??? (blue1999vette)
Vinci controller permanently installed on fender apron near hood cylinder.
Fred K.
Old Jan 8, 2004 | 10:24 PM
jl240z's Avatar
jl240z
Default Re: 160 degree thermostat??? (FKING1)
How much does a vinci controller go for and where do I get one? Does it do both fans or just one? Where is the best place to get the 160 deg thermostat. We dont worry much about the cool air down here unless it stops coming out of the dashboard :lol:
To 160 degree thermostat???
Old Jan 8, 2004 | 10:49 PM
angryfly's Avatar
angryfly
Default Re: 160 degree thermostat??? (jl240z)
Personally, I wowuld pay someone with LS1EDIT to reprogram your computer rather than butcher your wiring with aftermarket devices. IMHO
Old Jan 9, 2004 | 05:11 PM
FKING1's Avatar
FKING1
Default Re: 160 degree thermostat??? (angryfly)
Bought my Vinci from West Coast Corvettes but Ecklers also sell for $250. You do not have to butcher the wiring as the unit plugs in to the factory connectors. think it controls only one fan but not sure. I agree that it is much cheaper to have someone reprogram the fans. I wasted $$.
Fred K.
Old Jan 10, 2004 | 10:43 AM
Evil-Twin's Avatar
Evil-Twin
It is so cold outside today , that when I took a wizz outside I had to break it off to zip up my fly... the wizz had frozen to my peeper... :blueangel: :) :reddevil
You do Not want to have a 160 in your car on a day like this.... -16 in Syracuse NY today.. and thats NOT the wind chill,,,
