Clutch question
Old Jan 7, 2004 | 12:06 PM
00c5coupe's Avatar
00c5coupe
Default Clutch question
Recentlly...temps in dallas, tx dropped below 30 degree. When the car cold...the clutch pedal travel like about 2 inches and back to normal when the car get hot. What's the problem and what need to be done?
Thanks!
Old Jan 10, 2004 | 06:48 PM
TenaciousD's Avatar
TenaciousD
Default Re: Clutch question (00c5coupe)
Mine does the same thing in really low temps. I doubt it's anything to worry about.
Old Jan 11, 2004 | 12:47 PM
Stock Man's Avatar
Stock Man
2015 C5 of Year Finalist
St. Jude Donor '05-'06-'07-'08-'09-'10
Default Re: Clutch question (TenaciousD)
I have seen other threads on this and they suggest bleeding the system before it gets so bad that the pedal stays on the floor. Hope this helps. Also the consensus around here is to change the fluid every two years max.
Old Jan 11, 2004 | 03:33 PM
Z06ufgrad2002's Avatar
Z06ufgrad2002
Default Re: Clutch question (Stock Man)
I replace the clutch fluid just about every month to help prevent these types of problems. I don't bleed the whole system as this is way too labor intensive for a monthly choir. I just extract the fluid in the reservoir and pour in clean fluid. It really doesn't take long for the stuff to turn black again. Then I repeat the procedure. I do the same for the brakes as well.
Old Jan 11, 2004 | 10:06 PM
Kaley@DragonRace's Avatar
0Kaley@DragonRace
Supporting Vendor
Default Re: Clutch question (Z06ufgrad2002)
You change you tranny fluid every month?? Doesn't that expensive? Kaley
To Clutch question
