Oil temperature problem - help!
Old Jan 7, 2004 | 06:33 PM
Aviator's Avatar
Aviator
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In IV Veteran
Default Oil temperature problem - help!
I parked my car overnight in cold temps - low about 25 degrees. When I started the car the next afternoon, outside temps were about 35 degrees, and the Oil Temp readout in the DIC simply said "LOW". As I drove the car home, the "LOW" reading never disappeared, and I never got a numeric reading. Actual oil temp was probably about 202 degrees. All other temp and pressure numbers were normal.
This has never happened before in either of my C5's. Anyone have any ideas?
