Rattle from my Breathless Shifter...
Old Jan 9, 2004 | 01:44 PM
clean99's Avatar
clean99
Default Rattle from my Breathless Shifter...
Installed a new Breathless shifter and it rattles like a bag of marbles when taking it to a high rpm... Everything is tightened down...Any suggestions?
KTL302@***.NET
Old Jan 9, 2004 | 03:40 PM
clean99's Avatar
clean99
Default Re: Rattle from my Breathless Shifter... (clean99)
ttt
Old Jan 9, 2004 | 04:03 PM
ALLKAR's Avatar
ALLKAR
Senior Member
Cruise-In V Veteran
I switched shift ***** (helped a little) and I just tried the tennis ball trick, but haven't driven the car yet to see if that worked. :confused:
I think most after market shifters rattle. :smash: :smash:
Old Jan 9, 2004 | 11:13 PM
clean99's Avatar
clean99
Default Re: Rattle from my Breathless Shifter... (ALLKAR)
ttt
Old Jan 10, 2004 | 12:19 AM
ALLKAR's Avatar
ALLKAR
Senior Member
Cruise-In V Veteran
I'll get the Z out tomorrow. Let you know if the tennis ball trick worked!
Breathless is supposed to have a fix for the rattle. :rolleyes:
Old Jan 10, 2004 | 08:56 AM
Corpsvette's Avatar
Corpsvette
Veteran: Marine Corps
I did the tennis ball on the Hurst. Helped a lot but still a tad of rattle left. Not nearly as bad.
Jim K.
Old Jan 10, 2004 | 10:40 AM
clean99's Avatar
clean99
Default Re: Rattle from my Breathless Shifter... (Corpsvette)
What is the tennis ball trick?
Old Jan 10, 2004 | 12:49 PM
ALLKAR's Avatar
ALLKAR
Senior Member
Cruise-In V Veteran
Just got back from a test run. the tennis ball trick worked!! :yesnod:
Cut a tennis ball in half and then cut a slot for the shifter, then slide the tennis ball down over the shifter . EASY!!! :thumbs:
Old Jan 10, 2004 | 02:06 PM
clean99's Avatar
clean99
I'll try it out...
Thanks!!!
Old Jan 10, 2004 | 02:21 PM
chuckster's Avatar
chuckster
Try this... I am sure you will like it.. ;)
http://forums.corvetteforum.com/zerothread?id=720594
To Rattle from my Breathless Shifter...
