steering wheel sqeek
Old Jan 10, 2004 | 07:50 PM
Fast98's Avatar
Fast98
Default steering wheel sqeek
My steering wheel sqeeks when I make a sharp turn at low speeds,mind you the temp out side is only single #s. I saw a fix in the tech section but I can not tell where to spray the white grease from the picture,anybody know?
Old Jan 10, 2004 | 07:57 PM
2001 Red Coupe Bandit's Avatar
Default Re: steering wheel sqeek (Fast98)
Mine just Started doing this last week.
It makes a creeking noise.
tell me when you find out what to do to fix it.
Gary :D
Old Jan 10, 2004 | 08:11 PM
Fast98's Avatar
Fast98
Default Re: steering wheel sqeek (2001 Red Coupe Bandit)
I know something kneeds to be lubed I just cant tell from the picture.
Old Jan 10, 2004 | 08:51 PM
I am gonna put some wesson oil on it and see if that fixes it.
Just Kidding :confused: :eek: :D :lol:
Old Jan 10, 2004 | 11:22 PM
Monster231's Avatar
Monster231
Mine makes an annoying sqeel as well, WTF
Old Jan 11, 2004 | 12:36 AM
MacMan's Avatar
MacMan
Default Re: steering wheel sqeek (Monster231)
Same squeek here, mostly when it's cold out. : lame.
Old Jan 11, 2004 | 12:52 AM
Jimmy Smits's Avatar
Jimmy Smits
Default Re: steering wheel sqeek (MacMan)
Mine sqeeks whether it's hot or cold.... :mad Anyone know what the deal is?
Old Jan 11, 2004 | 02:07 AM
Default Re: steering wheel sqeek (Jimmy Smits)
It can't be that hard guys. I just don't knwo what to do to fix it, someone will chime in soon, we just need to be patient :rolleyes:
Old Jan 11, 2004 | 09:58 AM
UAWDES1's Avatar
UAWDES1
Mine is more of a groaning noise. I attribute it to the wider tires on the front. Been wrong before though :confused:
KJ
Old Jan 11, 2004 | 12:41 PM
Kenny94945's Avatar
Kenny94945
TTT...
Ditto the picture is not very clear.
My also squeaks; seams to be at the hub behind the air bag as opposed to under the dash or in the engine bay.
I am hesitant to just insert a nozzle and silicon spray into this area because of the electronics.
Old Jan 11, 2004 | 01:05 PM
MacMan's Avatar
MacMan
Default Re: steering wheel sqeek (Kenny94945)
Yeah, my squeek is right behind the airbag/steering wheel as well. Just seems like the plastic pieces are rubbing, like there isn't enough space between them. It's really annoying, and quite embarrasing if you have a passanger in the car.
We shouldn't have to grease interior plastic. lol
[Modified by MacMan, 12:07 PM 1/11/2004]
Old Jan 11, 2004 | 05:14 PM
Umrswimr's Avatar
Umrswimr
From: Overwhelmed as one would be, placed in my position.... DFW, TX
St. Jude Donor '05
Mine squeaks too...
:lurk: :nonod:
Old Jan 12, 2004 | 12:18 AM
Jimmy Smits
Default Re: steering wheel sqeek (Umrswimr)
Someone has to know how to fix this....ANYONE???
Old Jan 12, 2004 | 04:19 AM
Arkay's Avatar
Arkay
I have asked my dealer about it and does not sqeek for them and I get the 'can't duplicate customer problem" as the answer.
Sure would like to see a picture of where and how to fix this situation. Prior reading this posting I assumed mine was the only sometimes squeeker
Old Jan 12, 2004 | 02:01 PM
B. Stewart's Avatar
B. Stewart
Default Re: steering wheel sqeek (Dick Kriss)
This is a common problem that is fairly easily fixed. The squeeking/moaning from the steering wheel is coming from the steering shaft bushings. If your hand is small enough to get to the upper nylon bearing towards the firewall you can spray it with white moly grease. I actually taped a couple of the little "straw type" extensions together in order to reach it. There is also a lower bearing towards the steering box that is easy to lube. I think that if you do a search you can find some photos also.
Old Jan 12, 2004 | 02:08 PM
MacMan's Avatar
MacMan
Default Re: steering wheel sqeek (B. Stewart)
Thanks for the tip. I'll get under there this week and see if I can find it.
P.S. I bet your Palm Destert temp. display pisses a bunch of people off this time of year. ;) Yesterday it was 76 degrees in Irvine, CA. Yummy. Tonight I fly to SLC, Utah, where it was 19 degrees this morning. :P
Old Jan 12, 2004 | 02:24 PM
99blackFRC's Avatar
99blackFRC
https://www.corvetteforum.com/techti...D=35&TopicID=1
To steering wheel sqeek
Old Jan 12, 2004 | 02:39 PM
Arkay's Avatar
Arkay
Default Re: steering wheel sqeek (99blackFRC)
The link works but the second picture seems to be broken on this Mac. The first picture show a can spraying somehting. It was hard to tell what was being sprayed from where. Maybe the second (broken) picture clarifies the location of what to spray?
Old Jan 12, 2004 | 02:46 PM
B. Stewart's Avatar
B. Stewart
MacMan, you are right, it's been great here. My son lives in SLC (Sandy) and yes it is cold!
In the above link it is showing the lower bushing. In my situation it was the upper that was making all of the noise. The bushings are white nylon.
Old Jan 12, 2004 | 05:43 PM
Fast98's Avatar
Fast98
Thanks all I will give it a look soon
