Superchips or Autotap
Old Jan 13, 2004 | 03:11 PM
love2dye4u's Avatar
love2dye4u
Default Superchips or Autotap
Has anyone used superchips or autotap to increase performance? Any comments on the items? Thanks
Old Jan 13, 2004 | 03:21 PM
jmX's Avatar
jmX
Default Re: Superchips or Autotap (love2dye4u)
Autotap is just a logging scanner, its not going to increase performance.
LS1Edit will let you edit the tables in the PCM, and thus, you can increase your performance that way. I've used it, in conjuction with time on the dyno, and got power from it...but you need to know a little about what you are doing for sure.
For a novice, a pre-made tune is probably going to be your better option.
Old Jan 13, 2004 | 03:52 PM
c5chris's Avatar
c5chris
:iagree:
The question you should be asking should be LS1Edit or Predator? :jester
To Superchips or Autotap
