DIC codes.........O2 Sensors I think
Jan 17, 2004 | 10:06 AM
I am getting 3 DIC Codes...........
PO133 H C
P1134 H C
P1154 H C
Does anyone know what this is???
Jan 17, 2004 | 10:39 AM
Cruise-In V Veteran
St. Jude Donor '04
Re: DIC codes.........O2 Sensors I think (z28plus)
These are all 02 sensor related did you recently do some work that involved the sensors?
Jan 17, 2004 | 07:54 PM
I just purchased it, and the previous owner said that one or more may need replaced?? I there a way to tell which one??
Jan 17, 2004 | 08:05 PM
your faults are for both front o2 sensors.the guy you got the car from knew about this? strange,something smells.
Jan 19, 2004 | 03:48 PM
Re: DIC codes.........O2 Sensors I think (dpd)
may i ask how you can tell it is the front 2? What would the codes be if it were the rear 2 sensors?
Jan 19, 2004 | 06:32 PM
Jan 19, 2004 | 06:55 PM
Re: DIC codes.........O2 Sensors I think (B. Stewart)
thanks, but i have that already, I am just wondering how you know what bank 1 is or bank 2 etc........
Jan 19, 2004 | 07:10 PM
I wish I knew more to tell you but if it is the front o2 you need to replace them since they are an important part of the fuel system. They tell the PCM to go richer or leaner. If they are the rear they sit behind the CATS and are simply for emmision testing tests OBD2 and you don't need to worry too much until inspection time. Bank 1 and 2 suggest which side if the engine they are on. Sensor 1 is in front of cat 2 behind.
[Modified by Michael Joslyn, 12:11 AM 1/20/2004]
Jan 20, 2004 | 03:17 PM
Bank 1 is driver side, bank 2 is passenger side.
