Header gaskets and bolts?
Old Jan 17, 2004 | 06:50 PM
Y2KRoadster's Avatar
Y2KRoadster
Default Header gaskets and bolts?
I am getting some coated TPIS headers and was wondering which gaskets you guys would recommend and any install tips. Also, are the factory bolts good enough to use as well? Thanks a bunch!! :cheers:
Old Jan 17, 2004 | 07:11 PM
Dugmole's Avatar
Dugmole
St. Jude Donor '12-'13-'14-'15-'16
Default Re: Header gaskets and bolts? (Y2KRoadster)
Believe it or not the factory gasket is as good or better than most. Bolts as well.
Old Jan 17, 2004 | 07:23 PM
88sk's Avatar
88sk
Default Re: Header gaskets and bolts? (Dugmole)
put my KOOKS headers on last week & reused stock gasket& bolts they work great ,no problems.
Old Jan 17, 2004 | 08:09 PM
dpd's Avatar
dpd
ecklers has a nice split-loc header bolt set for ls1/ls6 engines that won't back out after they are locked.factory gaskets are the best.
Old Jan 18, 2004 | 09:09 AM
Kaley@DragonRace's Avatar
0Kaley@DragonRace
Supporting Vendor
Default Re: Header gaskets and bolts? (dpd)
When I did mine I used the factory gaskets. My headers came with bolts so I used them. Kaley
Old Jan 18, 2004 | 10:23 AM
runamuk's Avatar
runamuk
Cruise-In V Veteran
St. Jude Donor '04
I used the paper gaskets that came with my FLP headers and I started to have exhaust leaks after about a month, when I removed the headers to replace the heads I found every exhaust port except 1 or 2 were leaking so when I get the heads back on I'm using stock gaskets. :cheers:
Old Jan 18, 2004 | 10:00 PM
lowdowndirty's Avatar
lowdowndirty
Default Re: Header gaskets and bolts? (runamuk)
Use the stock gaskets. It is virtually impossible to obtain a leak-free install w/ paper gaskets. The factory bolts will work just fine. However, if you
R & R the manifolds or headers a few times, I would replace the bolts. Repeatedly tightening (especially OVER-tightening) fasteners will fatigue the material and they will work themselves loose. If you have any doubts pick-up some ARP's. Good luck, Chris. :thumbs:
Old Jan 18, 2004 | 10:29 PM
fsuforever's Avatar
fsuforever
i just put some on my car & they fit like aglove the drivers side was easier for me than the passengers side i did have topull the alternator & loosen the steering linkage , pull the coilpacks,oilfilter, valvecover,they should go right in ,passengers side coilpacks ,valve cover ,did not have to drop the starter they fit well u should recieve aset of lock washers with your headers i did just use your lock washers & use the old manifold gasket tip :take the back header bolts out first :thumbs:
Old Jan 19, 2004 | 05:10 PM
HP_Addict's Avatar
HP_Addict
Use the GM gasket and none other. I debated the bolt thing a while back. I ended up buying the ones with the locking tabs, forget the brand name. They are a steel coated bolt. However I have yet to install the locks. Too much trouble. Just be sure to use anti-seive on the bolts.
Chris
Old Jan 19, 2004 | 05:15 PM
frodo84's Avatar
frodo84
Uneducated autodidact
Default Re: Header gaskets and bolts? (marlowchris)
I'm going to use the "dead soft" gaskets, I've used them before on other applications and liked them. I will also use the locking header bolts (stainless Stage 8)....just my opinion though.
Old Jan 20, 2004 | 04:31 PM
wrustywrench's Avatar
wrustywrench
Default Re: Header gaskets and bolts? (frodo84)
I bought felpro ls1 manifold gaskets, they are metal on both side with somthin in the middle,,,used the stock bolts with antisieze and just made sure they were tight,,,,,anybody have feedback on this,,,,,I did not use lock washers or locktite,,,,just antisieze, I will check after I run the car fr a while
Old Jan 20, 2004 | 04:37 PM
B. Stewart's Avatar
B. Stewart
Default Re: Header gaskets and bolts? (wrustywrench)
Should be fine. Just re-torque the bolts after a few hundred miles. :cool:
To Header gaskets and bolts?
