DiabloSport: Eliminates 1-4 skip shift?
Old Jan 18, 2004 | 05:48 PM
Guest
Guest
Posts: n/a
Default DiabloSport: Eliminates 1-4 skip shift?
I thought the Predator was supposed to allow you to eliminate the 1-4 skip shift. I've just uploaded the program and I don't see a manual skip shift adjustment anywhere. Is it part of the base performance tune?
Does anyone know what the adjustments are to the Predator 'base performance tune' on the Spark and PE measures?
Old Jan 18, 2004 | 06:58 PM
LittleBoyBlu99's Avatar
LittleBoyBlu99
Default Re: DiabloSport: Eliminates 1-4 skip shift? (MMI)
:nonod: :hat :withstupid:
Old Jan 18, 2004 | 08:14 PM
Guest
Guest
Posts: n/a
They state that the Predator does this for 6-speed GM cars right on their website! What's the deal? :banghead:
Old Jan 18, 2004 | 09:21 PM
99 The Hard Way's Avatar
99 The Hard Way
Yes, it does eliminate it. it even stops the light from coming on. Go to "modify parametrs & scroll till you find it. It's been a while, so I can't remember exactly where in the menu it is located. When in doubt- read thru the intructions. ;) SCOTT
Old Jan 18, 2004 | 10:54 PM
Guest
Guest
Posts: n/a
Default Re: DiabloSport: Eliminates 1-4 skip shift? (99 The Hard Way)
I still don't see it anywhere -- there's nothing noted in the instructions for M6 cars. I wonder if that feature is only is offered by RunninWithTheDevil.com?
Old Feb 1, 2004 | 12:11 PM
RWTD's Avatar
RWTD
Actually, it is suppose to do it in the defaulted base program. There isn't any "end-user" option to disable it. By an error, not every F and Y body Predator programming will disable this. Until a new revision comes out, it will require a custom tune to defeat it.
Sincerely...
Old Feb 1, 2004 | 12:18 PM
WWK888's Avatar
WWK888
Default Re: DiabloSport: Eliminates 1-4 skip shift? (RWTD)
Take it back...
Old Feb 1, 2004 | 12:38 PM
corvette184's Avatar
corvette184
Default Re: DiabloSport: Eliminates 1-4 skip shift? (WWK888)
works just fine with mine.....the light even stays off.... :thumbs: :thumbs:
Old Feb 1, 2004 | 01:21 PM
RWTD's Avatar
RWTD
Again, please read what I stated above. This will clear up the confusion! Thanks!
To DiabloSport: Eliminates 1-4 skip shift?
