shroud for the zip-tie mod
Old Jan 19, 2004 | 11:02 AM
beckel's Avatar
beckel
Default shroud for the zip-tie mod
Fellow corvette freaks,
I have just done the zip-tie mod. SOTP is definitely improved. I have not dynoed it, but power has definitely increased. My question is the following.
Has anyone attempted to build a shroud over the open airbox ?
Old Jan 19, 2004 | 02:04 PM
mcd_57's Avatar
mcd_57
Default Re: shroud for the zip-tie mod (beckel)
I didn't :lurk:
Old Jan 19, 2004 | 03:21 PM
andy82's Avatar
andy82
2017 C7 of Year Finalist
Pic-tures ! Pic-tures! :smash:
Old Jan 19, 2004 | 09:27 PM
CSDMagRed01's Avatar
CSDMagRed01
Default Re: shroud for the zip-tie mod (andy82)
I just cut everything I could on the stock cover so I had a perimeter frame to hold the filter and as much open space in the center for better breathing. Have dremel tool will travel....
Old Jan 19, 2004 | 09:33 PM
LittleBoyBlu99's Avatar
LittleBoyBlu99
Default Re: shroud for the zip-tie mod (CSDMagRed01)
:cool: :cool:
Old Jan 19, 2004 | 10:37 PM
J-Rod's Avatar
J-Rod
Default Re: shroud for the zip-tie mod (LittleBoyBlu99)
Nope, if folks are worried, they usually use a weather strip along the front edge of the hood to keep water out of the filter. Y could cut up the stock box, but I think a hood gasket is a better idea.
Old Jan 19, 2004 | 10:51 PM
ClarksZ06's Avatar
ClarksZ06
Default Re: shroud for the zip-tie mod (J-Rod)
Yeah, I just used some weather stripping to prevent any water dripping onto the filter. Don't but a shroud on it, it will just restrict air flow.
Old Jan 19, 2004 | 11:15 PM
CSDMagRed01
Default Re: shroud for the zip-tie mod (ClarksZ06)
:iagree:
I also put weather strip under the front edge of the hood. Keeps water out of the exposed filter.
To shroud for the zip-tie mod
