How do you adjust the light? When its down its not flush with hood like the other one. Can I adjust this and how????? Please help...it bugs the hell out of me.... :U
From: GOCC - Rebels Without A Clue Santa Barbara, CA
Re: Light adjustment......HELP (JSMITH1615)
1. Raise the hood, and turn the **** on the headlight motor until the light is all the way up.
2. Remove the 3 phillipshead screws on the black plastic bezel.
3. Remove the 4 torx screws that hold the painted cover on. (To remove the two screws on the engine compartment side you might have to lower the light partialy)
4. Remove the painted cover. Under it you will see 4 plastic capture nuts. You can adjust them to flush the light.
5. Reverse the process.
