Not looking too good for Amsoil. There is an on going study right now comparing various oils in the LS1 engine. At only 2,000 miles, Amsoil's TBN is down to a 5.5. The gurus over at Bobistheoilguy.com are saying this is very low for such a short interval. This is the 5w-30 oil and not their 0w-30. As far as wear goes, we are talking about parts per million which won't really show anything to drastic until a few thousand more miles are added on. Should be interesting! :cheers:
The TBN drop is disturbing, but it could also be lab error too, so the main thing to look at is how the next few samples go.
As I predicted, lead is down. I predict you'll see a major advantage as the miles get put on, that Amsoil will show a lot lower wear numbers, especially for lead (which is bearing wear) Iron is a bit higher than I predicted so far though.
any oil that contains high amounts of hi pressure additive will oxidized quickly. that is why syn racing oil is not a good oil for long time between oil changes. mobil 1 was designed for long time between oil changes. :chevy
