Front Wheel Bearing Sensor
Old Jan 20, 2004 | 03:34 PM
Kenny94945's Avatar
Kenny94945
Default Front Wheel Bearing Sensor
Hello...
the service ABS, traction control error message that many are writing about lately seems to be caused by the this front wheel sensor.
Has anyone examined this bearing and the sensor?
In other words...could it be loose or dirty? Other?
Is the sensor sealed in the bearing negating only a replacement part to repair?
Old Jan 20, 2004 | 04:09 PM
davidfarmer's Avatar
davidfarmer
Default Re: Front Wheel Bearing Sensor (Kenny94945)
Your trouble code will tell you which sensor is bad, and it is just as likely a rear as a front.
Only repair is to replace the entire bearing assembly.
Dave
