Alignment Question. With......
Old Jan 20, 2004 | 05:33 PM
Cruises's Avatar
Cruises
Default Alignment Question. With......
2K Vert suspension upgrades with 2004 Z06 Shocks, Zo6 Sway Bar Kit, and Zo6 wheels it would seem like I should have the car aligned to Zo6 specs..... or would I ??? The springs are stock 2K and the car is not lowered. :yesnod: :yesnod: :nono: :nono: :confused: :confused:
Old Jan 20, 2004 | 10:49 PM
Cruises's Avatar
Cruises
Default Re: Alignment Question. With...... (Cruises)
ttt hey guys, with all the suspension mods on this forum someone must have thought about this before :confused:
Old Jan 21, 2004 | 12:48 AM
corvette dave's Avatar
corvette dave
I am not an expert on suspensions but will give you my opinion.
The suspensions are designed and built as a package. That includes tires.
I would not change the suspension without changing the whole thing, including the springs. Then you could go to a Z06 alignment.
Having said that, the Z06 alignment is one of the most overrated things here.
The settings are identical with the coupe/vert except the Z06 runs a little more camber. Do not get all hung up on that.
Do you have Z06 tires?
Just my opinion. Good luck with it.
Dave
[Modified by corvette dave, 11:49 PM 1/20/2004]
Old Jan 21, 2004 | 09:38 AM
Cruises's Avatar
Cruises
Default Re: Alignment Question. With...... (corvette dave)
Dave, thanks for the info......I just learned something new, I thought that there was a whole different set of specs for the Z06. I will have the Z06 wheels and tires by spring thaw. Again, thanks.... :cheers:
To Alignment Question. With......
