Super high oil pressure!
Old Jan 21, 2004 | 09:41 AM
ericdwong's Avatar
ericdwong
Default Super high oil pressure!
Alright I drove to work today and couldnt help but notice that my oil pressure gauge was pegged the entire way to work. I turned it on the DIC and it steadily climbed all the way up to 128 PSI! Da heck?
I dunno if the pressure was actually that high or if the sender unit is malfunctioning. Ill find out if it does it again later today when I go to lunch/leave.
Old Jan 21, 2004 | 09:47 AM
Duck916's Avatar
Duck916
Default Re: Super high oil pressure! (eRiCdWoNg)
I'll tell ya right now--it's the sender. This is a pretty common failure.
Old Jan 21, 2004 | 09:50 AM
Evil-Twin's Avatar
Evil-Twin
St. Jude Donor '03-'04
Default Re: Super high oil pressure! (Duck916)
Go to the top of this page and click on tools, then tech tips, then C5, then look for the topic oil pressure sender replacement.,.,,
Old Jan 21, 2004 | 09:58 AM
Patches's Avatar
Patches
Default Re: Super high oil pressure! (Evil-Twin)
'Nuf said. :yesnod: E-T's got you covered. :cheers:
Old Jan 21, 2004 | 10:14 AM
ericdwong's Avatar
ericdwong
Default Re: Super high oil pressure! (Patches)
OK good looks like an easy/cheap fix. My previous car (nissan maxima) also had oil sender issues (and it was the same size too). However in that car, an aftermarket unit from the local auto parts store was recommended over OEM. I wonder if this is the same case here...
Old Jan 21, 2004 | 12:42 PM
Evil-Twin's Avatar
Evil-Twin
the part number on the box in the tech tip is the lastest upgraded sensor.... the picture of the sensor on the tech tip is the old one.. and just for a visual reference..
Old Jan 21, 2004 | 01:22 PM
BlackMagicC5's Avatar
BlackMagicC5
When I first start driving my vette and its cold, the oil pressure usually goes up to about 60-70psi then after a while drops down to about 40-50 during cruise. Is this normal? It seems a bit high at 60-70.
Old Jan 21, 2004 | 01:27 PM
Patches's Avatar
Patches
Default Re: Super high oil pressure! (KillerVette99)
That's normal OP. I have a p&p oil pump and my pressure runs even higher than that.
Old Jan 21, 2004 | 02:38 PM
Evil-Twin's Avatar
Evil-Twin
Is that one of those pickle and pimento oil pumps?
Old Jan 21, 2004 | 03:10 PM
Patches's Avatar
Patches
No, Bill. It is puckered and primped. :lol: :cheers:
Old Jan 21, 2004 | 10:18 PM
SmashF15C's Avatar
SmashF15C
Hey patches et al, what about DIC = "low oil level" - any experience there?
Old Jan 22, 2004 | 11:18 AM
ericdwong's Avatar
ericdwong
OK good looks like an easy/cheap fix. My previous car (nissan maxima) also had oil sender issues (and it was the same size too). However in that car, an aftermarket unit from the local auto parts store was recommended over OEM. I wonder if this is the same case here...the part number on the box in the tech tip is the lastest upgraded sensor.... the picture of the sensor on the tech tip is the old one.. and just for a visual reference..
Apparently the one on the box is an outdated number now too. I called up with the # and the parts guy said it was no good, he then looked it up by the car and gave me 12573107 . Thats an expensive butt sensor at $55 list and GMparts is even $35 after shipping! Geeze, maybe I'll try pep boys. Good god. :mad
Old Jan 22, 2004 | 12:18 PM
FunDriver's Avatar
FunDriver
Veteran: Marine Corps
For over three years mine would start and run in the 45-50 range and then a couple oil changes ago it started going to 60-70 when started. After awhile it went back to the normal pressure. It seems to be ok and is maybe related to a change in the brand of oil filter, I'm not sure.
Old Jan 22, 2004 | 01:46 PM
ericdwong's Avatar
ericdwong
Default Re: Super high oil pressure! (FunDriver)
So I called the local chevy dealer for this part, and they actually pointed me to the cadillac dealer down the road. So I go there, get the part and the guy said $55 but ill give you 10 off. I figured it was $10 off but it was actually $10% and plus 5% sales tax = $52 :mad Gm parts direct wants $35 for it shipped, dang o well I have the part I might as well go put it in.
So then I went to play the onstar game while sitting in a deville and I lost :mad
Old Jan 22, 2004 | 05:06 PM
ericdwong's Avatar
ericdwong
Holy crap! The instructions in tech tips is WAYYYYYYYYY abbreviated. Dang, what a chore to get that thing out. I just took a break from alot of swearing, moving the intake manifold is a pain in the butt. You have to disconnect alot more wires and lines then it had stated. And theres this one line under the TB that is coolant, and when you pull that coolant goes everywhere! This better fix the prob or I'm gonna be even more :mad Now I'm tryin to find way to clean out all the crap thats between the intake and the block without dumpin all the grit and sand down the intake holes! :eek:
Old Jan 22, 2004 | 05:46 PM
Evil-Twin's Avatar
Evil-Twin
you dont have to disconnect any wires or fuel lines.. its a 45 minute job... you do Not have to remove the intake.. just move it forward.. about six inches... no fuel line disconnect... no injector line disconnect...some things that are obvious .. you clean the area around the intake so when you lift it up and forward no dirt goes into the intake chambers.. these things are all given.. when you remove any component from your engine..OH wait .. should I tell you to protect your fenders while working on the motor???? If you dont have basic mechanical savy you should not be messing with your motor.. MMany people have emailed me with their success on fixing this problem.. And their thanks...sorry if it was not good enough for you...and your expertice.
Old Jan 22, 2004 | 06:33 PM
ericdwong's Avatar
ericdwong
Holy crap! The instructions in tech tips is WAYYYYYYYYY abbreviated. Dang, what a chore to get that thing out. I just took a break from alot of swearing, moving the intake manifold is a pain in the butt. You have to disconnect alot more wires and lines then it had stated. And theres this one line under the TB that is coolant, and when you pull that coolant goes everywhere! This better fix the prob or I'm gonna be even more :mad Now I'm tryin to find way to clean out all the crap thats between the intake and the block without dumpin all the grit and sand down the intake holes! :eek: you dont have to disconnect any wires or fuel lines.. its a 45 minute job... you do Not have to remove the intake.. just move it forward.. about six inches... no fuel line disconnect... no injector line disconnect...some things that are obvious .. you clean the area around the intake so when you lift it up and forward no dirt goes into the intake chambers.. these things are all given.. when you remove any component from your engine..OH wait .. should I tell you to protect your fenders while working on the motor???? If you dont have basic mechanical savy you should not be messing with your motor.. MMany people have emailed me with their success on fixing this problem.. And their thanks...sorry if it was not good enough for you...and your expertice.
I know I was a little POd at the time but still, I know you wrote the article and i've very greatful for that, however it says to remove "coil covers, the air bridge, and the wires connecting to the injectors." Nowhere does that mention the coolant lines (that spilled all over the place for that matter) or the other vaccuum lines wasnt too obvious at first. Also the wrench size is 1 1/16th and the part number as stated above has changed.
FYI although ive never done any internal engine work I have however rebuilt transmissions (by myself) and pretty much any other bolt on component imaginable, on various cars and motorcycles. This was the first time for this one for the c5 and the sensor is quite buried. Again not bagging on your article but I felt as though there were some things that could have been added. and again, I know you wrote the article and i've very greatful for that. And yes, it did appear to fix the problem. :cheers:
[Modified by eRiCdWoNg, 6:37 PM 1/22/2004]
To Super high oil pressure!
