Which dynamometer?
Old Jan 21, 2004 | 11:31 PM
CORTVET's Avatar
CORTVET
From: Putting a 50¢ sticker of the U.S. Flag on a $50,000 import does not make one a patriot.
Default Which dynamometer?
What dynamometer do you use to tune, and get you rwhp/tq on? Which one is the best one out there to tune on?
I have tried the DynoJet and a Dyno Dynamics.
Thanks,
AZC5
Old Jan 22, 2004 | 12:18 AM
ArKay99's Avatar
ArKay99
Default Re: Which dynamometer? (AZC5)
I have used both DynoJet and Mustang dyno's.I like DynoJet dyno's because the numbers are a little higher and it makes me feel better about the work I did. Seriously, you can get good results on any dyno used for tuning. They are a tool and a good tool in the hands of a good tuner will get you good results. :thumbs:
Old Jan 22, 2004 | 01:30 AM
angryfly's Avatar
angryfly
Default Re: Which dynamometer? (ArKay99)
:iagree:
Old Jan 22, 2004 | 07:58 AM
lowdowndirty's Avatar
lowdowndirty
Default Re: Which dynamometer? (angryfly)
It realy doesn't matter. As long as you use the same one before and after the mods if you're using the dyno as a comparative tool. I think the Dynojet will read closer to the actual "factory" numbers. :thumbs:
To Which dynamometer?
