Dyno Results Within!
Old Jan 22, 2004 | 08:47 AM
XTrooper's Avatar
XTrooper
Default CORRECTED Dyno Results Within!
As it turns out, the 404 rwtq number was a false reading caused by a spike. :cry :D
The correct peak rwtq number was 355.
Well, I finally got the heads and LS6 manifold installed and the car dyno-tuned.
It made 388 rwhp and 355 rwtq. Not too shabby for an A4 car with a "baby" cam! :thumbs:
I didn't need any dyno numbers to know the car was making a lot more power. I only "thought" the car was fast before. It's scary fast now! :D
Even in 3rd gear, when I touch the throttle now, the car pushes you back in your seat. Before, with those tall 3.15 gears, it didn't really have much till the motor hit about 4000 rpm. Now the car pulls HARD from under 2 grand right to the 6500 rpm redline! :cheers:
[Modified by XTrooper, 3:50 PM 1/31/2004]
Old Jan 22, 2004 | 08:53 AM
03SpiralGray's Avatar
03SpiralGray
Default Re: Dyno Results Within! (XTrooper)
Nice numbers XTrooper. I have a coupe with an A4 and the 3.15 axle. I was thinking about doing a cam, which cam did you go with?
Old Jan 22, 2004 | 08:56 AM
XTrooper's Avatar
XTrooper
Default Re: Dyno Results Within! (03SpiralGray)
Thanks! :)
A custom grind. See sig for specs.
Old Jan 22, 2004 | 09:01 AM
C5JONNY's Avatar
C5JONNY
Nice #'s with that setup. :thumbs:
Old Jan 22, 2004 | 10:25 AM
pdd000's Avatar
pdd000
:thumbs:
Old Jan 22, 2004 | 10:46 AM
REDGAR's Avatar
REDGAR
Cruise-In II & IV Veteran
CI VI Drag Champ!
Nice job Steve.
Old Jan 22, 2004 | 11:03 AM
Caillou's Avatar
Caillou
I love that high torque number. :cool: :cheers: :thumbs:
Old Jan 22, 2004 | 11:29 AM
vstella's Avatar
vstella
...It made 388 rwhp and 404 rwtq. Not too shabby for an A4 car with a "baby" cam! :thumbs: ..XTrooper
Great #'s :smash: In fact they are the same #'s for me when I did my first H/C setup..I was running hi 11's at the time. Be warned that TRACTION WILL be an issue..Get some Drag Radials !! Good Luck:D
Old Jan 22, 2004 | 11:51 AM
myblackC5's Avatar
myblackC5
can i see your licsence and insurance, could you step out of the car.........
:lolg:
Old Jan 22, 2004 | 12:09 PM
Jackal's Avatar
Jackal
Those are some awesome numbers. I love that tq number. Where did you have it tuned?
Old Jan 22, 2004 | 12:12 PM
XTrooper's Avatar
XTrooper
Default Re: Dyno Results Within! (Jackal)
Thanks, fellas! :)
Installation and dyno-tuning done by Rapid Motorsports, Reading, PA.
[Modified by XTrooper, 12:13 PM 1/22/2004]
Old Jan 22, 2004 | 03:47 PM
Automag928's Avatar
Automag928
Real nice number! Congrats!! :thumbs:
Old Jan 22, 2004 | 05:54 PM
Kenny94945's Avatar
Kenny94945
I am envious....no cam or heads or tune on my A4 and it got 305 rear wheel.
That's a highly motivating report to buy heads/ cam.
Old Jan 22, 2004 | 06:11 PM
EFI-1's Avatar
EFI-1
Default Re: Dyno Results Within! (Kenny94945)
Nice #'s XTrooper! :cheers:
Old Jan 22, 2004 | 06:44 PM
1 BAD C5's Avatar
1 BAD C5
Great numbers :cheers:
Old Jan 22, 2004 | 08:02 PM
ClarksZ06's Avatar
ClarksZ06
You should be very happy with those numbers. Expecially all that torque! WOW. :thumbs:
Old Jan 22, 2004 | 08:51 PM
Dave00C5's Avatar
Dave00C5
Excellant Numbers!!!!! :thumbs:
To Dyno Results Within!
Old Jan 22, 2004 | 11:02 PM
427CPE's Avatar
427CPE
:cheers: on the numbers. What cam is that?? Can you post the dyno curve?
[Modified by 427CPE, 8:03 PM 1/22/2004]
Old Jan 23, 2004 | 05:45 AM
XTrooper's Avatar
XTrooper
Default Re: Dyno Results Within! (427CPE)
Well, it's known as the Trooper Cam II on LS1.Com where I've been a long-time member and moderator. The cam was custom ground to my specs by Comp Cams. :yesnod:
I'm waiting for Mike to scan in the dyno sheet for me. As soon as I get an image file, I'll upload and post it.
Old Jan 23, 2004 | 06:22 AM
chevysales's Avatar
chevysales
nice numbers xtrooper.
and awesome look on your vette, like your previous ss its a killer :)
