Cam vs 3.90 gear
Old Jan 24, 2004 | 01:25 AM
roushraven's Avatar
roushraven
Coolest Guy Evar!
Default Cam vs 3.90 gear
Hey guys I can't make up my mind.
I am heading back to 21MC for some more work but I can't make up my mind on which "power" enhancement to go with.
I have searched the boards and found that cam only ('02-up) cars without exhaust bolt-ons tend to make about 380-390 rwhp and tq. However, a cam install will very likely void the factory powertrain warranty. I have read a lot of positive feedback on the 3.90:1 gear change and even had the opportunity to go for a spin in a bolt-on Z with that gear. (That car was awesome , by the way. Anyway, as with the cam, the gear change will very likely void my drivetrain warranty.
Normally I wouldn't care about either of those two warranties with a modified car because my opinion is "if you play, you pay". Before I decided to buy my Z, I spent several months researching which owner issues were the most troublesome and all that I could find about Z's included the '01 ring problem, '01 exhaust rattle, the leaky rear seal, bad AGM battery and random electrical gremlins; all of which have been addressed by GM. In reality it seems very unlikely that I would ever need to worry about powertrain or drivetrain problems because the car is so well built in those areas.
So which should I do, please help me decide.
Thanks,
Arthur :flag
Old Jan 24, 2004 | 06:52 AM
Mitch C's Avatar
Mitch C
Default Re: Cam vs 3.90 gear (roushraven)
Do the 3.90 gears you will get better performance than if you just do a cam without the other bolt on's like headers. Plus depending on how mod friendly your dealer is the gears might not void your power train warranty.
Old Jan 24, 2004 | 09:13 AM
Mopar Jimmy's Avatar
Mopar Jimmy
From: Elmhurst, IL (West Suburb of Chicago) & Home of MEGA Horsepower
St. Jude Donor '06
Cam up that baby with headers, exhaust and air intake and you will be making plenty of power (between 400 and 430rwhp depending on the cam which is 500HP at the crank:D). IF not enuff then in the future throw in a 3.90 or 4.10 gear!:D
[Modified by MTI 427 Roadster, 8:15 AM 1/24/2004]
Old Jan 24, 2004 | 10:25 AM
zoomz's Avatar
zoomz
I am personaly going to do gears and TC before i do a cam .
You will notice a differance putting a cam in the car , but your going to freek out when you wrap out 3rd gear in a Z06 with a 390 gear .
With todays street condition and traffic problems , its pretty pointless for me to have a car that will run 175-200 mph , so im going to go with the 373 and a SS3000 , maybe even a SS3600 .
Old Jan 24, 2004 | 10:36 AM
NEPTUNEBILL's Avatar
NEPTUNEBILL
Default Re: Cam vs 3.90 gear (zoomz)
I doubt the dealer would even notice the rear gear, they look just like any other and if working under your hood I doubt they would even look or make an issue of it, engine mods work best together having a cam that will open the engine up and not having the intake and exhaust to get that mix in and out would limit your gains significantly, but a rear end and TC would be like an instant extra 100rw and it would not affect anything else in the car, you will be very happy with your choice--and there is always later on to find ways to spend more money believe me, you may find that you have more than adequate power with just the drive train changes and I doubt the rearend will affect your topend that much as the gear will let you rev much higher in top gear than you can stock--
Old Jan 24, 2004 | 10:54 AM
LittleBoyBlu99's Avatar
LittleBoyBlu99
Do the 3.90's and cam later.They want void warranty unless the gears are linked dirrectly to the problem. :thumbs: :cheers:
Old Jan 24, 2004 | 08:56 PM
robz's Avatar
robz
Default Re: Cam vs 3.90 gear (LittleBoyBlu99)
I did the 3.90's first and now I have both the gears and a cam on a z06. I think they compliment each other well. The good thing is, you can change either of them out if you like. And yes, the dealer didnt know I had 3.90s but he wouldnt miss the cam.
Old Jan 24, 2004 | 09:17 PM
PowerKraus's Avatar
PowerKraus
With gears you'll get immediate gratification, all the time, any speed.
The cam will get you a great feeling when you exceed the speed limit.
Go gears first! :seeya
PowerKraus
Old Jan 24, 2004 | 09:20 PM
pdd000's Avatar
pdd000
Default Re: Cam vs 3.90 gear (MTI 427 Roadster)
:yesnod:
Old Jan 24, 2004 | 09:27 PM
99LS1VETTE's Avatar
99LS1VETTE
Default Re: Cam vs 3.90 gear (robz)
I would do the gear. The dealer will never know.
Old Jan 24, 2004 | 11:26 PM
MC TORCH RED's Avatar
MC TORCH RED
Default Re: Cam vs 3.90 gear (99LS1VETTE)
:iagree:
Old Jan 25, 2004 | 12:02 AM
Kaley@DragonRace's Avatar
0Kaley@DragonRace
Supporting Vendor
Default Re: Cam vs 3.90 gear (MC TORCH RED)
I would say gears also. The dealer would be less likely to find out. I went with a cam first because I love the sound of a lopey cam. I am now in the process of getting my gears in. Just waiting for them to arrive. kaley
Old Jan 25, 2004 | 02:55 AM
MagRed01Atty's Avatar
MagRed01Atty
Default Re: Cam vs 3.90 gear (2C5only21)
Just make sure you take peek under te rearend after te install of gears. I recently had mine on the lift and noticed that the last shop had written 3.90 in sharpe on the case. Hard to miss that.
Old Jan 25, 2004 | 08:13 AM
roushraven's Avatar
roushraven
Coolest Guy Evar!
Default Re: Cam vs 3.90 gear (MagRed01Atty)
Hey everybody I have decided to go with the gear upgrade. The cam isn't out of the question but I think I need to consider whether or not I want to do heads and headers too or just go for broke and get a 427.
Thanks for all of your input
Arthur :flag
[Modified by roushraven, 7:15 AM 1/25/2004]
To Cam vs 3.90 gear
