Another possible cause for "warped" rotors
Old Jan 24, 2004 | 11:59 AM
Richin Chicago's Avatar
Richin Chicago
Default Another possible cause for "warped" rotors
Everytime somebody asks about doing brakes I try to tell them to grease the slide pins when they do the brakes. I just found from the guy at our local shop that "dry" or corroded slide pins will cause the brake pedal to pulse along with accelerated pad wear.
I never thought about it but if the slide pins can't slide the calipers can't float and the slightest amount of runout will be felt in the pedal. So make sure those slide pins get greased whether you do it yourself or a shop does it.
Click to magnify
Old Jan 24, 2004 | 12:30 PM
carpe dm's Avatar
carpe dm
Default Re: Another possible cause for "warped" rotors (Richin Chicago)
Good recommendation Rich! With the cold temps in Chicago though, I bet that grease is going to be pretty thick! :smash: :crazy: :D
Old Jan 24, 2004 | 03:00 PM
Richin Chicago
Default Re: Another possible cause for "warped" rotors (carpe dm)
Funny you mention that. I had the car out when it was -2 degrees last week. The engine must gain 50 HP while the tires aren't interested in sticking at all. Must be what it was like with an L88 and those old skinny tire of the late 60s.
To Another possible cause for "warped" rotors
