C5R heads CCs?
Old Jan 24, 2004 | 08:43 PM
NJ99FRC's Avatar
NJ99FRC
From: If you can see the car behind you, your not going fast enough
Default C5R heads CCs?
Does anyone know how many cc's they are... I imagine they are some where in the high 50s :cheers:
Old Jan 25, 2004 | 08:36 AM
marco383's Avatar
marco383
Default Re: C5R heads CCs? (NJ99FRC)
More like the high 30s. One of the many issues involved in adapting C5R heads is obtaining a C.R. usable with pump gas.
Old Jan 25, 2004 | 12:37 PM
NJ99FRC's Avatar
NJ99FRC
Default Re: C5R heads CCs? (marco383)
They are really that low?
Now i am wonder how lingenfelter runs those heads w/ 427 CID and twin turbos @ 24 lbs.?
Crazy how they do it...
DOes anyone have an exact #? Thanks
Old Jan 25, 2004 | 01:29 PM
Gene@FredBeans's Avatar
Gene@FredBeans
They are now in the 30's, the new part #. From what I understand you have to port them on your own!
Gene
Old Jan 25, 2004 | 02:35 PM
marco383's Avatar
marco383
Default Re: C5R heads CCs? (Gene@FredBeans)
I don't believe that LPE runs C5R heads on their 427TT. A lot of people are using the C5R block (I am), but IMHO, the heads present more problems than can be justified by the breathing improvements they offer.
Old Jan 25, 2004 | 04:02 PM
Major Spray's Avatar
Major Spray
The 8 sec LPE car runs C5R Heads and Block
Old Jan 26, 2004 | 12:50 PM
kromberg's Avatar
kromberg
Default Re: C5R heads CCs? (Major Spray)
The 'standard' C5R head uses 38cc chambers. The 'high performance' version uses 30cc chambers.
I have heard that the 38cc version can have the chambers expanded out to 44cc. Using the biggest dish piston of -38cc with a 427 would yeild a static compression ratio of 9.8:1. You could most likely run about 10 psi of boost on 104 unleaded.
Keith
Old Jan 26, 2004 | 02:27 PM
drouns's Avatar
drouns
Default Re: C5R heads CCs? (kromberg)
Keith
DAMN :D
To C5R heads CCs?
