2003 Z06 Oil Temperature
Old Jan 25, 2004 | 09:45 AM
GP's Avatar
GP
Cruising
Default 2003 Z06 Oil Temperature
Has anyone experienced a “Low Oil Temperature” on the drivers display even after the coolant is at operating temperature?
Greg
:confused:
Old Jan 25, 2004 | 12:13 PM
gmblack3's Avatar
gmblack3
Default Re: 2003 Z06 Oil Temperature (GP)
Greg, That is how the system works when the OAT is 15* or below. You can turn the key to the start position while the car is running, (will not harm anything) then the system will be reset:
http://www.z06vette.com/forums/showt...light=oil+temp
Old Jan 27, 2004 | 01:18 PM
JC in XTC5's Avatar
JC in XTC5
Default Re: 2003 Z06 Oil Temperature (gmblack3)
Performing the "Hot Reboot" with the key does not always work. In my case the oil temp only resumed to normal operation after shutting down for a few minutes.
When I encountered this for the first time a few weeks ago I did an extensive search and found this to be a common issue - must be a S/W designer's way of busting our nut!
To 2003 Z06 Oil Temperature
